renault rs26 wrote: ↑04 Jun 2023, 18:04We are so lucky Max Verstappen is here, otherwise this would be another Mercedes/Hamilton win.
And what exactly is wrong with that?renault rs26 wrote: ↑04 Jun 2023, 18:04We are so lucky Max Verstappen is here, otherwise this would be another Mercedes/Hamilton win.
It'll be a small fine realistically
Your sarcasm radar needs fine tuning.dans79 wrote: ↑04 Jun 2023, 18:09And what exactly is wrong with that?renault rs26 wrote: ↑04 Jun 2023, 18:04We are so lucky Max Verstappen is here, otherwise this would be another Mercedes/Hamilton win.
George had a fantastic start clearing Perez and Gasly off the line, before turn 1 he was already 3 wide with Hulkenberg and Piastri. They got through turn 1 together but Russell was squeezed on the inside of turn 2, took to the escape road and rejoined 9th between Hulkenberg (8th) and Piastri (10th).
Likely just a fine. But you never know. The stewards might give pity for harsher penalties given its been quite a while since Merc had drivers on the podium.
I think he went 3 wide on purpose. Knowing he could then use the run-off. No way 3 cars can fit through turn 1 so it would always end up in being forced off track. Quite smart.Raleigh wrote: ↑04 Jun 2023, 18:32George had a fantastic start clearing Perez and Gasly off the line, before turn 1 he was already 3 wide with Hulkenberg and Piastri. They got through turn 1 together but Russell was squeezed on the inside of turn 2, took to the escape road and rejoined 9th between Hulkenberg (8th) and Piastri (10th).
And arguably the only reason that was 9th instead of 10th is Piastri had a horrible turn 2 exit, dropped 5-6 car lengths behind Hulkenberg and ended getting passed by an Alfa Romeo on the exit of turn 3.
Absurd! 3- wide into turn one was happenstance, which resulted in George making a quick exit. Don't be ridiculous .Sieper wrote: ↑04 Jun 2023, 18:58I think he went 3 wide on purpose. Knowing he could then use the run-off. No way 3 cars can fit through turn 1 so it would always end up in being forced off track. Quite smart.Raleigh wrote: ↑04 Jun 2023, 18:32George had a fantastic start clearing Perez and Gasly off the line, before turn 1 he was already 3 wide with Hulkenberg and Piastri. They got through turn 1 together but Russell was squeezed on the inside of turn 2, took to the escape road and rejoined 9th between Hulkenberg (8th) and Piastri (10th).
so whats this procedure that they infringed on? seeing that its from the media delegate id
Zhou right behind was 3 wide with Perez and Gasly, he made it work to come from behind and overtake both on track 3 wide through 1 and 2.Sieper wrote: ↑04 Jun 2023, 18:58I think he went 3 wide on purpose. Knowing he could then use the run-off. No way 3 cars can fit through turn 1 so it would always end up in being forced off track. Quite smart.Raleigh wrote: ↑04 Jun 2023, 18:32George had a fantastic start clearing Perez and Gasly off the line, before turn 1 he was already 3 wide with Hulkenberg and Piastri. They got through turn 1 together but Russell was squeezed on the inside of turn 2, took to the escape road and rejoined 9th between Hulkenberg (8th) and Piastri (10th).
