Thats F1. Sometimes a team and their driver do their work well and dominate. Its up to other to catch up. If you can't stand watching it, you are better off watching spec racing like Indy.PlatinumZealot wrote: ↑20 Jun 2023, 09:12My main point was Max in unchallenged so there is no fight for the win, much less to even lead him on a lap.napoleon1981 wrote: ↑20 Jun 2023, 05:04There is some exaggeration going on here. Max got 4 consecutive wins. Lewis has done 5 wins atleast twice on separate occasions. Rosberg did 7. Perez is 9 points in front of alonso. Look at the dominant merc years. Both drivers were marching away. Thats the sign of a dominant car. We now have a dominant driver
Result of Number 1 driver in dominant car in era of reliabilty.
In the Canadian race his engineer said something so damning... "Max those behind you are pushing harder than you are".... While Max was 10 seconds down the road complaining about heating the tyres..
Can't blame them, but it certainly dampened the race.
they said not much.. they had trouble getting tyre temps to work and had no brake temp issues.napoleon1981 wrote: ↑20 Jun 2023, 15:47I wonder how much time that bird in the brake duct was worth for verstappen.
I saw that as well, I think the car like Krack said is not optimized yet, for example he had quite a bit of oversteer with the Mediums and due to the phantom issue he had to put the braking bias multiple clicks forward, so the driving was more erratic than other races, not nailing the corners consistently. At least that means a little bit more pace if they get it right for Austria. After all instead of the maximum of 3 free practice sessions it was just 1 really, due to rain and red flags and CCTV and everything.Juzh wrote: ↑20 Jun 2023, 00:43Anyway, I looked at full alonso's onboard and it's very possible without the lift & coast he'd right up there with verstappen. He was doing it from like lap ~25 and it really did cost him quite some time, also with his driving, as he was very much more error prone in a few corners before and after (saying error, but actually just sub-optimal). Apart from T9 excursion, T10 was particularly not optimal from there on after. While chasing Hamilton without LC he was hitting the apex more or less every time even in dirty air. After he overtook him and started LC it was a rarity to see him do an optimal apex. T13 was also causing some troubles. Add to that extra time lost with the coast and you can see how gaps in pace can quickly emerge.
.KimiRai wrote: ↑20 Jun 2023, 16:55.Juzh wrote: ↑20 Jun 2023, 00:43Anyway, I looked at full alonso's onboard and it's very possible without the lift & coast he'd right up there with verstappen. He was doing it from like lap ~25 and it really did cost him quite some time, also with his driving, as he was very much more error prone in a few corners before and after (saying error, but actually just sub-optimal). Apart from T9 excursion, T10 was particularly not optimal from there on after. While chasing Hamilton without LC he was hitting the apex more or less every time even in dirty air. After he overtook him and started LC it was a rarity to see him do an optimal apex. T13 was also causing some troubles. Add to that extra time lost with the coast and you can see how gaps in pace can quickly emerge.
Yes, completely agree, without issues Alo could have been very close then. Especially if the start would have went better for him. Max had a very good launch fortunately (if you like to see him win).Juzh wrote: ↑20 Jun 2023, 10:10Well apparently it was a phantom issue, not something they intended to doSieper wrote: ↑20 Jun 2023, 00:51But why was he doing that? If the option to not do it is not on the table the deficit is still real. Cars performance is the sum of all parts. Plus, redbull didn’t have the ideal set-up on a track that doesn’t suit them especially well. On others the gap will be bigger imho.
https://www.racefans.net/2023/06/19/alo ... terialise/
this could very well mean alonso ended with too much fuel in the end, causing more slowdown
RBs problems on this track were fundamental to the car, not anything in particular to do with setup. Gap could and probably will be bigger in next races, but on this past sunday alonso could be very close without that problem, as I said.
It is harder to hold position amongst frontrunners than with mid field, especially if the cars are closer in performance.
