How stalled diffuser/wing decrease drag?
Fluido
Fluido
Re: How stalled diffuser/wing decrease drag?
Vanja #66 wrote:
22 Dec 2023, 13:11
Fluido wrote:
22 Dec 2023, 12:47
But if atmospheric pressure is 101 325 Pa, we can't go below -101 325 Pa.
Pressure can't be below 0. Zero is minimun.
So how much -17 Cp will be?
Well you did confirm there is a local supersonic flow, so at one point there will be a normal shock wave and the flow is slowed down and back to subsonic. There are also, of course, sudden local changes in pressure and temperature.
I calculated for 67m/s and sea level pressure 101325 Pa , I get it -63 168 Pa, this is -0.6bar, this sound impossible to get so high suction at the wing!!
Fluido wrote:
22 Dec 2023, 17:59
I got 0.55 bar static pressure on that point, but yeah, it's possible. It's very local, remember that. Cp of -8 is more spread in that example, which is "only" 0.8b static pressure and that's far more reasonable :)
#Aerogimli
Fluido
Fluido
Vanja #66 wrote:
22 Dec 2023, 22:53
Fluido wrote:
22 Dec 2023, 17:59
-17=p-101325 /(0.5x1kg/m3x67m/s^2)
p=63168 Pa is static pressure, barometric pressure
I made mistake..... 63168 Pa -101325 Pa = suction is -38 157 Pa this is -0.38bar, still big
67m/s is 241km/h,F1 car speeds
hollus
Am I the only one thinking that by the time (before, actually) your model gets a supersonic region, neither your equations (no longer incompressible fluid) are adequate nor your wind tunnel (different supersonic point) is realistic?
I was under the impression that these models break down well before supersonic anything.
Rivals, not enemies.
hollus wrote:
23 Dec 2023, 00:55
Good point. I would have to jog my memory to be honest, but yeah the local supersonic flow is changing things. I haven't been studying transonic nor supersonic flows a lot after my studies. The local supersonic flow leads to drag divergence due to local normal shockwave generation, but I can't tell how it infulences local pressure field and if subsonic coefficient calculations are valid. Supersonic flow (global) has very different coefficient expression, but I don't know what happens with local supersonic cases.
#Aerogimli
Fluido
Fluido
Vanja #66 wrote:
23 Dec 2023, 20:27
hollus wrote:
23 Dec 2023, 00:55
Do you know which NACA profiles they use for rear main wing and flap?
jjn9128
769
Fluido wrote:
03 Jan 2024, 08:54
In F1?
#aerogandalf
Fluido
Fluido
jjn9128 wrote:
03 Jan 2024, 11:30
Fluido wrote:
03 Jan 2024, 08:54
In F1?
Yes.
Or this profiles are not from NACA family?
jjn9128
769
Fluido wrote:
03 Jan 2024, 13:31
jjn9128 wrote:
03 Jan 2024, 11:30
Fluido wrote:
03 Jan 2024, 08:54
In F1?
Yes.
F1 wing profiles are not from any aerofoil family. They're drawn parametrically by eye and experience using splines/curves.
#aerogandalf
