Williams FW46
Farnborough
Farnborough
89
Re: Williams FW46
Cs98 wrote:
20 Feb 2024, 14:08
tomazy wrote:
20 Feb 2024, 13:46
Rear pull rod suspension on merc gearbox??
Maybe they elected not to take the new gearbox?
Looks like a render image, Vowles stated they didn't want to "jump" their supplier, Mercedes, in publishing the rear suspension and gearbox detail.
Deferred to MB in other words.
By all account it'll be the full Merc package on here when clear view is available of the real car.
Cs98
Cs98
25
Re: Williams FW46
Farnborough wrote:
20 Feb 2024, 14:16
Cs98 wrote:
20 Feb 2024, 14:08
tomazy wrote:
20 Feb 2024, 13:46
Doesn't look like a render to me. Looks like they kept last years layout. We'll see.
Holm86
245
Re: Williams FW46
Cs98 wrote:
20 Feb 2024, 14:18
Farnborough wrote:
20 Feb 2024, 14:16
Cs98 wrote:
20 Feb 2024, 14:08
Definitely not a render, and it looks like the W14 rear suspension not the W15.
cplchanb
cplchanb
Re: Williams FW46
Hasn't williams historically built their own gearbox despite being a merc customer? This is prob still it.
On a side note, give this car some dignity and sticky this thread!
Venturiation
Venturiation
98
Re: Williams FW46
Re: Williams FW46
101FlyingDutchman
101FlyingDutchman
Re: Williams FW46
Packaging has always been a signature Williams strong point. Looks tidy on the whole. Will they get suspension kinematics up to big boy level. Single lap pace was good but race pace quite often lacking
Farnborough
Farnborough
89
Re: Williams FW46
Cs98 wrote:
20 Feb 2024, 14:18
Farnborough wrote:
20 Feb 2024, 14:16
Cs98 wrote:
20 Feb 2024, 14:08
Which image ? The ones posted by "gavingav1" with lens resolution of component highly detailed (effectively from static images and depth of field, with acutance of v-high shutter speed, if it was really moving) contrasted with wheel spin and track surface artificially "moving" to make it look like it's actually on track ?
Noooo, not a render at all :mrgreen: if that's the image being referenced and showing the rear suspension layout.
Cs98
Cs98
25
Re: Williams FW46
Farnborough wrote:
20 Feb 2024, 15:49
Cs98 wrote:
20 Feb 2024, 14:18
Farnborough wrote:
20 Feb 2024, 14:16
Yup, don't think that's a render. We will see who is correct soon enough. Williams have been on track in Bahrain filming today.
FW17
168
Re: Williams FW46
I guess Williams have continued using the 2023 gear casing. I guess the casing which houses the suspension should have a longer life that the gear cassette.
I guess Williams are able to use the 2024 Merc gear cassette with the old 2023 casings.
Might have saved some money too.
Re: Williams FW46
FW17 wrote:
20 Feb 2024, 16:01
Williams switched to 2024 focus well before others. Could be also that their processes and required lead times meant they needed to finalize a rear suspension and gearbox design further in advance than mercedes could supply them with final '24 designs. See it with alpha tauri every year running older RB suspension
Holm86
245
Re: Williams FW46
Farnborough wrote:
20 Feb 2024, 15:49
Cs98 wrote:
20 Feb 2024, 14:18
Farnborough wrote:
20 Feb 2024, 14:16
The photo is taken by a car moving the same speed as the Williams, so the movement of the Williams relative to the camera is zero, I don't see anything that suggest this is a render ...
tomazy
tomazy
205
Re: Williams FW46
Winglet on front wing endplate is unique, it gets thicker, it is more like a triangle than a winglet. I also think there is a lot les bulk behind the airbox than last year, here is a pic of FW45 for comarison.
gavingav1 wrote:
20 Feb 2024, 13:33
Full Frontals
Re: Williams FW46
tomazy wrote:
20 Feb 2024, 16:11
Winglet on front wing endplate is unique, it gets thicker, it is more like a triangle than a winglet. I also think there is a lot les bulk behind the airbox than last year.
Good spot on both fronts. Airbox definitely slimmer from Rosario Giuliana's comparison
And this is the funky dive plane. Brand new (chunky) solution. What are they doing with it
MTKF1
MTKF1
Re: Williams FW46
Is it me or does the rear wing look reduced area wise to the one that tested last year? The front wing looks pretty similar in terms of surface area (but more refined), but the rear wing definitely looks smaller.
Would this indicate that they've maintained or even increased the amount of downforce generated by the floor of the car and can therefor remove some rear wing whilst maintaining balance with the front. Or is it still to early to say?
Last Year Testing
Today's image
