Red Bull RB20
Cs98
Cs98
Re: Red Bull RB20
Indeed. Something stinks.
vorticism
323
Re: Red Bull RB20
I'll still wager they're letterbox, but the vertical inlet concept may have one advantage: easier adaptation of inlet size, track to track, similar to how their louvers last year were simple & serial and easy/cheap to alter per event.
Aside: motion to call it brim-pod.
𓄀
dren
226
Re: Red Bull RB20
Henk_v wrote:
15 Feb 2024, 19:19
There are 2 options here;
-Team red Bull is rolling on the ground laughing because they purposely leaked pictures of a bullshit car the internet can dissect.
-Team red Bull is rolling on the ground laughing because they will kick MB ass in a '22 MB, while MB is driving a '24 RB..
Any way you slice it they are having fun
#2 would be epicly hilarious.
Honda!
venkyhere
venkyhere
Re: Red Bull RB20
FW17 wrote:
15 Feb 2024, 19:24
venkyhere wrote:
15 Feb 2024, 19:22
Is this 'brightened pic' with a vertical cooling intake, a real image or an edit-joke by someone ?
No there seems to be a vertical dark slit when you brighten the picture
Pardon my ignorance, but it doesn't make sense to me, how this is going to route the boundary layer to go and hit the radiators inside the sidepod, without suffering serious losses. If it is going to be 'almost a slit' it has to be a horizontal letterbox under the overbite. Shifting the entry by 90 (especially with a massive thin-profile horizontal plane-wing forming the overbite) to deliver sufficient cooling AND a clean undercut flow, isn't too clever.
...OR ...
is it ?
Even if it's an S-duct entry to energize flow along a different axis, it looks too MASSIVE for that purpose, the disturbance to the undercut would be too costly a tradeoff, I feel.
Re: Red Bull RB20
vorticism wrote:
15 Feb 2024, 19:31
>It was cold during shake down
>They knew it was going to be cold during shake down
>They blocked off the inlets with sidepod fronts they'd never use later and ran the car using only centerline cooling
>It's a testing troll
Okay maybe not and I'll still wager they're letterbox, but the vertical inlet concept may have one advantage: easier adaptation of inlet size, track to track, similar to how their louvers last year were simple & serial and easy/cheap to alter per event.
I have never seen a team block off a radiator inlet completely. Isn't it possible there is both an s-duct and a horizontal inlet?
What is baffling to me is Adrian Newey's fear of having been conservative?
dren
226
Re: Red Bull RB20
The top of the sidepod front extension looks more like a separate wing. Wonder if these sidepods will come off?
Honda!
AMG.Tzan
38
Re: Red Bull RB20
LM10 wrote:
15 Feb 2024, 18:53
AMG.Tzan wrote:
15 Feb 2024, 18:46
Wow
Nose, sidepod inlets and engine cover bulges same as Mercedes last year! 😳
Probably Newey is trying to ridicule Mercedes by dominating with their own concept… 😂😂
This is by no means Mercedes’ zeropod concept.
Who said it’s zero pods??
I’m talking about the B spec W14 with overbite sidepods :wink:
vorticism
323
Re: Red Bull RB20
15 Feb 2024, 19:38
Was just joking. Too off topic so I deleted it. Either Newey was throwing chaff or they had other more different concepts they were evaluating, although that seems a little unlikely to me considering the bodywork regs are so restrictive now. I'm not seeing the value of an S-duct. I have my doubts about how useful the concept is. You want outwash maxxing so why redirect air from that area.
𓄀
FNTC
FNTC
Re: Red Bull RB20
dren wrote:
15 Feb 2024, 19:39
Something is definitely going on here. Either the whole vertical inlet is a decoy or maybe they show up at testing or the first race with zeropods.
Re: Red Bull RB20
I think testing will have an updated sidepod. Let's see.
Re: Red Bull RB20
FNTC wrote:
15 Feb 2024, 19:42
dren wrote:
15 Feb 2024, 19:39
With the little windtunnel time that they have, they would not have spent any of it building decoys.
Henk_v
Henk_v
80
Re: Red Bull RB20
Well, thats the charm of decoys. They are fantasy and hence do not take up any windtunnel time. The car probably only has one sidepod...
FNTC
FNTC
Re: Red Bull RB20
15 Feb 2024, 19:52
FNTC wrote:
15 Feb 2024, 19:42
dren wrote:
15 Feb 2024, 19:39
Would be pretty cheap to slap on a vertical piece of carbon for those blurry studio shots if the actual inlet is letterbox shaped below that apparent wing on top of the sidepod. But who knows whats going on here.
SSScoffee
SSScoffee
Re: Red Bull RB20
Maybe my mind is imagining things at this point but that looks like a vertical inlet. For the final version it wouldn't make much sense running a vertical inlet then showing up in Bahrain with a horizontal. The Mercedes boys must be feeling dizzy, maybe their concept was not so bad after all
LM10
LM10
121
Re: Red Bull RB20
AMG.Tzan wrote:
15 Feb 2024, 19:42
LM10 wrote:
15 Feb 2024, 18:53
AMG.Tzan wrote:
15 Feb 2024, 18:46
Wow
If any, the RB20 we're seeing on the low quality pictures looks more like the launch spec W14 with an upper lip and a vertical inlet - of course if it's true that the RB20 actually has vertical inlets.
