McLaren MCL38
ashnathan
ashnathan
Re: McLaren MCL38
From an onboard view in sprint quali, there is quite a lot of flex in the front wing. Backs off a lot under load and lifts nicely back into place under braking, much more than normal.
Might be helping the efficiency of the new package, anyone notice this under braking after the long straight? I tried to watch other cars and they didn’t move anywhere near as much.
Re: McLaren MCL38
Good thread showing comparisons with pre Miami
Re: McLaren MCL38
Tomsky
Tomsky
Re: McLaren MCL38
Marble
Marble
Re: McLaren MCL38
The full thread and comparative pictures are here :
Tomsky
Tomsky
Re: McLaren MCL38
mwillems
26
Re: McLaren MCL38
The suspension fairing: revised to support the modification of the flow downstream of the front wing.
Image 1: Front view, modification to the exterior of the suspensions
Image 2: modification of the chassis anchor (subtle, but see the orange/black paint limit)
Give a man a fire, and he will be warm for a night.
Set a man on fire, and he will be warm for the rest of his life.
michl420
michl420
Re: McLaren MCL38
I also think the shoulder over the inner rear suspension, where the painting cut from orange to black, is higher. And maybe to the same dimension on his underside (rear push rod opening) tighter.
Re: McLaren MCL38
Re: McLaren MCL38
The shaping of the underside of the floor edge wing is particularly interesting
Re: McLaren MCL38
Mclaren will not be happy about that...
Spacepace
Re: McLaren MCL38
See Mercedes! This is a floor :D
Re: McLaren MCL38
There's a throat on the inside of strakes right behind the leading edge. Followed by a higher tunnel roof locally and a gradual decrease towards diffuser throat. Mercedes does, in fact, have a similar feature, all basically originating with RB18. Strake vortex is given a lot of room to develop and feed.
#Aerogimli
mwillems
26
Re: McLaren MCL38
04 May 2024, 23:29
https://i.imgur.com/zC6anNV.jpeg
https://i.imgur.com/l3QDGIL.jpeg
It's beautiful, almost like the contours are based on an ordinance survey map, it looks so natural.
Wow, and that's what I call a very flat spot on the right rear.
CaribouBread
CaribouBread
91
Re: McLaren MCL38
04 May 2024, 23:29
There's some fine symmetric sculpting on the keel, there is a channel that runs along the length of the keel. Seems unique.
