Does anyone know if the telemetry was looked at by the stewards or did they have to wait until after the race to see it?
I was under the impression they didn't see it until after the race?
Since the incident was not investigated, the telemetry was not looked atNathanOlder wrote: ↑17 Nov 2021, 23:47Does anyone know if the telemetry was looked at by the stewards or did they have to wait until after the race to see it?
They noted the incident and just 2 laps later they declared no investigation necessary; so that's 2 to 3 minutes for them to decide so I don't think they even saw anything other than the live picturesNathanOlder wrote: ↑17 Nov 2021, 23:47Does anyone know if the telemetry was looked at by the stewards or did they have to wait until after the race to see it?
Just depends on how much overtaking is possible in Qatar….Starkblood80 wrote: ↑18 Nov 2021, 00:45If and it’s a big if, the stewards decide to penalise max I would think a 3 place grid drop for the next race would be more beneficial to Mercedes than a retrospective 5 second penalty?
I feel like the stewards will probably say they were able to see that from the footage they had, and therefore their decision will remain unchanged. There's a slim chance this appeal will actually change the result, but if it does it could decide the championship, which is why Mercedes are going after it. It's the exact same reason Red Bull tried to do the same after Silverstone.adrianjordan wrote: ↑17 Nov 2021, 02:23But it didn't allow them to see him open up the steering slightly mid corner when he already had a good rotation and was not understeering.west52keep64 wrote: ↑17 Nov 2021, 01:59I think the chances the stewards will actually apply a penalty are incredibly slim. The onboard footage is certainly new and relevant evidence, but what is it proving exactly? The footage available on the day showed Max running wide without locking or sliding, and the stewards already ruled based on that.
Ouch.Restomaniac wrote: ↑18 Nov 2021, 01:18Just watched the race again. Masi is a liar.
When asked by Mercedes directly he said ‘having looked at it all completely it was one of those and obviously we’ve had a good look at it, Erm and that’s why we’ve gone for a no investigation’. We all know that wasn’t possible as they didn’t have Verstappen’s cockpit and telem. This is the key point IMHO. Mercedes could have them and him on toast.
I don't think anyone is really disagreeing with Ho-Pin's recounting of events (I agree with him too), but he did (deliberately) leave out the context of the situation. Namely, why Max was so late in the brakes to start with and why was he on the throttle on so early if he knew he was already heading off the track.Incognito wrote: ↑17 Nov 2021, 22:49I don't know why people are dunking on Ho-Pin Tung and, I suspect, not reading what he actually wrote.Wouter wrote: ↑17 Nov 2021, 15:32I assume you know Ho Pin Tung, a racing driver and F1 analyst, who always gives his unbiased analysis after every race on everything that happened in the race.
9:48 a.m. Nov 17 2021 Ho-Pin Tung
What VER thought was only he knows, so let's not speculate and limit it to facts. I always say: motorsport is physics.
Tire has max grip potential, which you can use in longitudinal direction (braking/acceleration), rotation (steering) or combination thereof ("combined G").
"Ask" too much grip from the tire, then you will block or you will have slip. Both brake here later than usual, have to slow down more to reach the bend. VER brakes later and on the inside line has to make a tighter radius, so slow down even more than HAM. Knowing max potential tire, braking straight ahead is most effective for slowing down ASAP.
That explains why VER sends in relatively little, because at that moment it needs all (more than usual) band potential to slow down. Only when the braking phase is largely over, can it use more potential to rotate, and then also sends a large angle but is already on the edge of the track.
Had he sent in earlier (and more), then blocked LF or lost control, and probably hit HAM in both cases.
That's some speculation I want to do and just give extra info so everyone can make up their own mind.
Paragraph 1: Tyre grip has a limit
Paragraph 2: If you exceed that limit, bad things happen. Verstappen brakes later than Hamilton, on a tighter radius, and is already going faster. To maximise grip, he would brake in a straight line.
Paragraph 3: Verstappen doesn't try to make the corner, because he knows he's going too fast.
Paragraph 4: Had he turned tighter he'd spin and hit Hamilton.
Does anyone actually disagree with this?
Ho-Pin Tung isn't saying Verstappen didn't divebomb Hamilton and force him off the track. He's saying the opposite of that. Verstappen came in too fast (only Verstappen knows if it was deliberate), couldn't make the turn, so drove off the track with Hamilton trapped on the outside. As intent has no bearing on the rules, Ho-Pin Tung is actually in the Mercedes camp.
He could say exactly the same about Bottas in Hungary. He came in too fast, couldn't brake in time, hit Norris. To say those things isn't to argue Bottas didn't deserve a penalty, it's merely an observation of the facts.
