Where are the valves? Two stroke?johnny comelately wrote: β28 Apr 2022, 09:19This is our old test mule showing the dual flame jet ignition where it was cast welded inserts and went too lean (methanol) causing the burn out/in on one cylinder. Unconventional engine design, dont ask
3 mm holes, 94 mm bore
https://images-wixmp-ed30a86b8c4ca88777 ... tOt0o2XJq0
