The new splitter...
It has a cooling hole so it probably contains more stuff than before indeed
AMuS
Old
I love how you can see vortices forming behind the front wheelSmallSoldier wrote: ↑07 Oct 2022, 13:30Wet sessions always provide cool pictures:
https://i.imgur.com/oPyxL47.jpg
Via: Suzuka Circuit
Even though the rain does help visualize a few things, with water been heavier than air, it is not an actual representation of what is happening with the air flow… But it gives a general idea… For the most part, you will see most teams showing very similar patterns.
They've done about as much as they can for the undercut this year, it's pretty tight down there, it'll be interesting to see how revised the cooling solution is next year and the sidepod shapes they choose to run with. I assume it will be more sculptured with a bigger undercut but who knows.Blackout wrote: ↑17 Oct 2022, 14:43A nice pic of the internal ducting of the cooling air
https://i.imgur.com/Bee5OvU.jpg
The sidepod inlets don't change at all in that view, so not the highest level of detail.SmallSoldier wrote: ↑27 Oct 2022, 19:39An interesting view of the changes to the MCL36 from the launch version:
I think the geometries are pretty spot on for the changes so far… May be lacking some detail, but it is a good reference to understand how much it has changedmwillems wrote: ↑27 Oct 2022, 22:54The sidepod inlets don't change at all in that view, so not the highest level of detail.SmallSoldier wrote: ↑27 Oct 2022, 19:39An interesting view of the changes to the MCL36 from the launch version:
I'm not convinced by some of the other comparisons,.namely the RB one where it has the sidepods getting substantially wider through the season, which hasn't happened at all. This is basic geometry that they're failing withSmallSoldier wrote: ↑28 Oct 2022, 04:38I think the geometries are pretty spot on for the changes so far… May be lacking some detail, but it is a good reference to understand how much it has changedmwillems wrote: ↑27 Oct 2022, 22:54The sidepod inlets don't change at all in that view, so not the highest level of detail.SmallSoldier wrote: ↑27 Oct 2022, 19:39An interesting view of the changes to the MCL36 from the launch version:
