Hi guys, my first post here.Ashwinv16 wrote: β26 Jan 2023, 03:44Some speculation on design from a bit of snooping
- Car will use Mercedes's entire rear end components allocation, so Gearbox and Suspension
- There Is a some possibility of a L-Shaped Sidepods(Higher expectation for Alpine to have this too). Apparently if designed right, you get the low drag benefits of the Red Bull, the Aero advantage of the Ferrari and the Mercedes combined. (This is also the small loop hole everyone talking about, where the sidepods can be stretched out to make it bit to allow air to be diverted away from the rear wheels, but the central tunnel will let the air flow freely to the rear diffuser like the Alpine, in a more extreme way
With regards to your second point didn't Mclaren attempt this design on the MP4-26 to a certain degree?
