mzso wrote: ↑20 Mar 2023, 17:00
Engine development is not covered by the cost cap. And buying suspension, gearbox, etc is covered. So I don't see how customers have an advantage. I'm quite sure Mercedes or other suppliers don't sell the parts so cheap as to disadvantage themselves.
The engines are set cost yes, and aren't what the point of my post was about, I'm saying they are supplied by Brixworth. The parts Mercedes supplies are separate to the above.
Mercedes designs, develops, builds and tests these parts, which are at a cost the team. These parts are then sold for an unspecified price.
I'll put it this way so as maybe you see. If half the chassis(rear suspension and gearbox) is set at a production cost, this leaves Design, testing and research costs separate.
The problem of "suppliers don't sell parts so cheap as to disadvantage themselves" is that's not compatible with the rules.
The supplier must also provide their customer with all relevant financial information, with the financial regulations dictating the parts must be ascribed a “fair value” for cost cap accounting purposes.
So from the list I have included, Aston Martin can source 50% of these items at "fair value" which is agreed between AM and Mercedes. This can be fair value at cost of production. And therefore Aston free up cash to develop elsewhere.
If the parts are too expensive to sell at fair value, Aston would be building there own.
That they aren't suggests that the set up is advantageous to the them. Would you have information to suggest otherwise?
What is fair value? What would the cost of Researching, developing, testing and producing the parts, as opposed to the cost of purchasing? As I've said....this could potentially be a gaming of the system.
One requires a department to do it all, one that's covered by the cost cap, and another doesn't even have that department.
The list of items is comprehensive:
Rear impact structure
Gearbox carrier
Gearbox cassette
Clutch
Clutch actuation system
Clutch shaft
Gearbox internals
Gearbox auxiliary components (oil system, reverse gear etc)
Inboard front suspension
Front suspension members
Front upright assembly (excluding axles, bearings, nuts & retention system
Front axles (inboard of the contact surface with the wheel spacer) and bearings
Inboard rear suspension
Rear suspension members
Rear upright assembly (excluding axles, bearings, nuts & retention system)
Rear axles (inboard of the contact surface with the wheel spacer) and bearings
Power assisted steering
Fuel system components not listed as OSC or SSC or LTC
Hydraulic pump and accumulator
Hydraulic manifold sensors and control valves
Pipes between hydraulic pump, hydraulic manifold & gearbox or engine actuators
Secondary heat exchanger (in oil and coolant system)
Power unit mountings to gearbox and survival cell
Exhaust system beyond turbine and wastegate exits (which are covered by PU rules)
Electrical looms
