https://www.planetf1.com/news/lando-nor ... .%E2%80%9D
An extremely strong response for "those believing their own BS" that the rear wing made anything more than a minor difference.
It was interesting to hear views from the team perspective in trying form actions in countering this aspect of tire compromise.Mostlyeels wrote: ↑27 Nov 2024, 04:34Another parallel tidbit: no (or not many) lockups going into corners on race day (or on cold tyres coming out of the pits), versus lots of lockups in practice, from a wide range of drivers and teams. Brake bias adjustments for that would be further to the rear normally? Obviously factoring out adjusting the braking point and driver skill.Farnborough wrote: ↑26 Nov 2024, 11:10Interesting they changed it on the fly to specifically counter front .? graining. Speculation, but likely would incorporate brake balance further forward, no coast into brake zone, higher diff locking possible in corner in trying to "push" front of chassis into front tire "conflict" mildly.
Hard application of brake with front bias (this is what "brake magic" did ) to generate more wheel temperature, lateral understeer to promote more tire temp, combination too bring up overall wheel & tire assembly in to sweet spot and reduce graining.
I think the latter. As they built new wings based they included added flexibility where appropriate, rather than designing wings just to get flexibility.Ben1980 wrote: ↑27 Nov 2024, 10:50I'm not at all techy. But my query on the amendedments to all rear wings, why design it as it was if negligible impact? Or were they designed as they were changed to, but with the "trick" knowing it can be sorted.
I would expect the team to downplay it's impact though.
Minor differences are everything in F1. These cars are bespoke but several can be separated by less than a tenth of a second over a 4+ km circuit.mwillems wrote: ↑27 Nov 2024, 09:21https://www.planetf1.com/news/lando-nor ... .%E2%80%9D
I have to agree.
That, probably inadvertently, EXACTLY describes why the wing was designed built and implemented by this team.mwillems wrote: ↑27 Nov 2024, 12:52I think the latter. As they built new wings based they included added flexibility where appropriate, rather than designing wings just to get flexibility.Ben1980 wrote: ↑27 Nov 2024, 10:50I'm not at all techy. But my query on the amendedments to all rear wings, why design it as it was if negligible impact? Or were they designed as they were changed to, but with the "trick" knowing it can be sorted.
The reason why it isn't going to make that big a deal is because the drag only really starts to make a difference over 220-250+kph
At Vegas, we were one of the fastest over the straights. We actually lost most of our time from the start finish through to turn 7/8 which has one mid speed corner that we have been struggling with for most of the season, the rest being low speed corners that this wing or one with a bit more DF is unlikely to help with much. The suffering at Vegas looks more to be with the way we were able to enter the slow speeds with other teams able to carry more speed on entry to the corner. Front end traction under breaking seemed to be the issue.
It's not a myth, but on wings the size used at Vegas, it's also not going to make any real difference and the tops speed gain would likely be 1kph or less due to much smaller amount of wing flex.Farnborough wrote: ↑27 Nov 2024, 13:57That, probably inadvertently, EXACTLY describes why the wing was designed built and implemented by this team.mwillems wrote: ↑27 Nov 2024, 12:52I think the latter. As they built new wings based they included added flexibility where appropriate, rather than designing wings just to get flexibility.Ben1980 wrote: ↑27 Nov 2024, 10:50I'm not at all techy. But my query on the amendedments to all rear wings, why design it as it was if negligible impact? Or were they designed as they were changed to, but with the "trick" knowing it can be sorted.
With it there, top speed it enhanced,, while maintaining wing load as speed comes off for those type corner.
Without it .... flap compromise to keep top speed, leads to reducing load into that type corner. This also (low download rear) brings a corresponding reduction in front flap required to balance the two, leading to front graining. EXACTLY what we saw in that Las Vegas race.
Those that have watched this for detail over the years can see that clearly from the race evidence, it's not a myth.
It's not pure load, everything he was talking about to make it work had nothing to do with load it was about how they treated the tyres. You can't increase DF from the onboard settings, you can adjust the balances and other non DF settings and alter the way you throw or push the car into the corner with your steering inputs.Farnborough wrote: ↑27 Nov 2024, 14:25"The gaps here had nothing to do with the wing, IMO, and everything about mechanical traction, partially down to how we could get the car to interact with the tyres."
Interaction with the tires is pure load, from the wings and floor. Take any away from that total and it'll get harder, choices less, driver confidence diminished, etc. Graining increased and so forth. It's there in plain sight.
Stella even confirmed this in his words of "Extreme set up shift from drivers steering wheel controls" or words to that effect. Those to counter load missing from the setup they chose to Q and race with.
Didn't they run a high DF wing than others? That would increase load wouldn't it?Farnborough wrote: ↑27 Nov 2024, 21:07Not load ? Really.
Its always load, the whole purpose of down force is to load the tires. They didn't run the necessary level here, factually illustrated by tires staying below temperature, not matching those around them, again factual in Q & race.
There's no suggestion from me that they can increase load from steering wheel setting, only supplement/supplant that missing load through "Extreme" (Stella description) setting. Thats the same as formation lap type behaviour when speed is not there to apply aero load.
Its speculation on my part exactly what driver changes were made, but from informed point of view.
They didn't or couldn't use the wing they would like while keeping top speed competitive. That's what a flex rear wing was about.
The physics of that showed here, by moving them back against those three team cars finishing ahead of them. Thats not speculative, they have to answer to physics not me.
Likely they'll have a better balance mix at this race with the corner type that is primary focus this track.
I was referring to load without being more specific as I was talking within your parameters of load from the wing and floor. Yes, the tyres work through load. The mechanical loading is latitudinal and longitudinal and is not the same type of load as comes from downforce.Farnborough wrote: ↑27 Nov 2024, 21:07Not load ? Really.
