2024 Scuderia Ferrari F1 Team
yooogurt
40
It was not an easy choice, so much so that it was made only a little more than half an hour before the QP Sprint, after a long analysis of FP1 data: Leclerc will use in QP and the Sprint the new floor. (c) Donadoni
FORZA FERRARI!
jambuka
jambuka
Hold your horses guys. McLaren often makes a massive step from FP to qualifying.
dialtone
dialtone
121
Watched the replay of FP1.
Hinchcliffe said Ferrari is a bit twitchy in T4, although I didn't see much of that in the soft runs but LEC made an error in entry to T5 on his fast lap where he took too much kerb and had to lift a bit, so maybe there's something to it.
LEC also complained that he had a bit too much traffic in S1 on his lap so he couldn't take the best line in T2-3.
T10-16 looked really good, but Lando was nowhere close to the kerbs in those corners, he was going slow but it's hard to know if it's due to lack of confidence/car or simply he wanted to go slow there.
That still looked like a very easy lap to put together. My hopes aren't up yet, but certainly encouraging FP1.
jambuka
jambuka
3rd best over 1 lap ?
SoulPancake13
SoulPancake13
Charles really struggled in SQ2 with front tyre temps. Hopefully SQ3 goes better.
Xyz22
Xyz22
123
SoulPancake13 wrote:
29 Nov 2024, 20:04
This small tyre window has been a problem since the start of the season, crazy.
Anytime Sainz does better, the plethora of excuses come out for Leclerc...
A lion must kill its prey.
yooogurt
40
Damn
FORZA FERRARI!
SoulPancake13
SoulPancake13
That's a bit ---.
Track temps drop and we are nowhere, both drivers complained about understeer on their final runs. I hope 2025 can fix this issue because it is just plain annoying at this point.
.Bole
.Bole
Bad quali again, bad prep for this weekend. We are experimenting too much.
Too much understeer
Xyz22
Xyz22
123
This is what i expected lmao...
Probably way less fuel in FP1.
ScuderiaLeo
The drivers were only 0.027 apart. I think they were on low fuel loads earlier, plus track temp dropping and soft tires may have made things more difficult.
Honestly we're much closer to pole than I expected coming into the weekend, so...
Anyways, we knew this would be a tough track though and McLaren would be stronger. Points are tomorrow, let's hope they can make up ground there.
Cs98
Cs98
33
Another statement from Sainz, not getting the upgrades but still putting it ahead.
SoulPancake13
SoulPancake13
Cs98 wrote:
29 Nov 2024, 20:24
I don't think it was really an upgrade if they only decide 30 minutes before SQ to put it on. Still, credit where credit is due.
MV8
MV8
Bad preparation for this SQ, let's see if they can do some work for tomorrow's qual.
Cs98 wrote:
29 Nov 2024, 20:24
You people are pretty boring around here. #-o
Just posting
