I think most interesting question is what going on behind!ringo wrote:Now we can discuss what's going on with this nose. It is similar to what I predicted.
Don;t forget that air has friction with layers flowing next to it so there would be an influence over the rest of the wing too, small, but present.ringo wrote:A picture is worth 1000 words
not 100% accurate but pretty close. (splitter was rushed )
cut plot
Now we can discuss what's going on with this nose. It is similar to what I predicted. Even though the pressure changes are not drastic; every little thing adds up.
The expansion is from the darker blue under the point of inflection between the wing supports. The good thing though, is that it is still in the atmospheric region of pressure after the expansion. I am guessing it could be harmless.
The nose is too narrow to create any real suction under it since the flow field to the sides are at atmospheric.
I will then say the arch in the nose is just to meet the regulated longitudinal area.
The nose was made very high and sloped to obtain down-force. Because of this tall nose, the cross section would be rather big if a straight line was used from the chin to the splitter like the Redbull. The arch is a way to take out some area under the nose while still being able to use that big blob at the tip of the car.
This simulation was done on a very basic mesh setting. It's gonna take some hours for better details with my little old PC.
This is just my opinion by the way, happy to hear any corrections.
Main differences are indeed down the whole of the centre...but then BGP believed they had made the most of the regulations last year so I wouldn't expect a dramatic change this year, just more refinement.JohnsonsEvilTwin wrote:Look at the comparison earlier in the thread, I think you will find the diffuser as a whole is 99.99% the same, save for the joining section which will be different as its a different car. Every picture i have seen suggests so.
Have you seen more of the diffuser? Can you point me in the right direction to seeing the pic????
What's going on at the car floor Ringo, is the flow being blocked there? I suspect that the flow here will have a significant impact on the development of the flow under the nose.ringo wrote:
Yeah, i don't have a bow there to divert the flow to the sides. The Splitter is supposed to stagnate some of the flow to put a high pressure on top to push the car to the ground. Drag is reduced with the bow, pushing the air to the sides then onto the floor.horse wrote: What's going on at the car floor Ringo, is the flow being blocked there? I suspect that the flow here will have a significant impact on the development of the flow under the nose.
