What would you guess the cooling advantage is of running drilled disks?
I've been thinking and can't see how they are really an advantage. I mean, they might have a few % more surface area (??) but that surely wont help that much?
i know they build slotted discs to keep the fins free to pull air out of the center, but still get rid of the gasczt wrote:I've not really looked into it, but my understanding is that drilled discs reduced gas build up between pad and disc face and hence improve performance that way.
It is not the little % increase in surface area that will cause the cooling it is the fact that the hole will allow passage of air and that will lead to convective cooling. There is almost always a pressure difference on either side of the brake disk.djones wrote: I've been thinking and can't see how they are really an advantage. I mean, they might have a few % more surface area (??) but that surely wont help that much?
What are you using the car for?djones wrote:What would you guess the cooling advantage is of running drilled disks?
Short answer pads and fluid for sure. Discs will probably help, but you have done the important stuff with the pads and fluid. I would still wonder whether you would notice the drilled discs over standard ones, but fitting Brembo is a good idea anyway (quality stuff).djones wrote:The reason I ask is we are taking a TT to the Nurburgring this year and the standard brakes are pathetic to say the least.
OEM disks and pads they fade after about 5 100-40 MPH stops.
We can go 'track' pads such as the Ferodo DS3000 which will make a huge difference but we were wondering if it was worth swapping the OEM disks for Brembo Drilled disks (same diameter etc, just drilled).
Brake fluid will be changed for Motul RBF600.
djones wrote: We can go 'track' pads such as the Ferodo DS3000 which will make a huge difference but we were wondering if it was worth swapping the OEM disks for Brembo Drilled disks (same diameter etc, just drilled).
Please don't look at what manufacturers use on their road cars for inspiration.djones wrote:But.... porsche etc fit drilled so maybe there is more to it?
