Renault R30
DM0407
DM0407
Re: Renault R30
Those brake ducts look, unexploited. Is there more to it or are they not using them as aerodynamic devices?
manchild
manchild
Re: Renault R30
Separate duct (I'd say for cooling of electronics).
Spencifer_Murphy
Re: Renault R30
manchild wrote:Separate duct (I'd say for cooling of electronics).
Electronics? What electronics are there in the uprights?
Surely the large one is to cool the brake discs and the smaller one to cool the calipers?
Silence is golden when you don't know a good answer.
manchild
manchild
Re: Renault R30
There's a lot of electronics in there. Not Renault pic, but irrelevant. Temp sensors, lock sensors, car's speed is also measured by front wheels rotation... who knows what else.
imightbewrong
imightbewrong
Re: Renault R30
Carlo's
Carlo's
Re: Renault R30
@up
Renault gearbox?
Re: Renault R30
Those 'alternative' brake ducts have been teted in Barcelona.
bar555
bar555
Re: Renault R30
Renault R30 brake ducts at Valencia
Future is like walking into past......
Blog : http://formula1techandart.wordpress.com/
Twitter :http://twitter.com/bar555onF1
Spencifer_Murphy
Re: Renault R30
manchild wrote:There's a lot of electronics in there. Not Renault pic, but irrelevant. Temp sensors, lock sensors, car's speed is also measured by front wheels rotation... who knows what else.
Oh I know about the sensors, but when cooling electonics aren't you often cooling the processors...the sensors wouldn't need that sort of cooling I thought?
Re: Renault R30
why would you even mind to put such parts wich are very heat sensitive near an part that produces alot of heat? that would simply be stupid.
manchild
manchild
Re: Renault R30
wesley123 wrote:why would you even mind to put such parts wich are very heat sensitive near an part that produces alot of heat? that would simply be stupid.
Because it is necessary and possible. It has been done for years. It's not the question of "is it there?" but "is the additional duct for it or not?".
Re: Renault R30
the sensors yep, but i really doubt if additional electronics are located there, why would you place it there if you can place it in the center wich actually reduces body roll(in a really slight rate). In the tub it is away from heat producing parts so it lasts longer
Sebp
Re: Renault R30
I always thought you put as little as possible into the hubs to reduce the unsprung mass.
manchild
manchild
Re: Renault R30
We misunderstood each other. Sensors are electronics - peripherals of ECU/blackbox/telemetry. They certainly aren't simply electric nor mechanic.
Tim.Wright
330
Re: Renault R30
No electronics in an upright would need cooling that is for sure. The whole upright probably draws well less than an amp. You only need cooling if you are running power transistors for actuators etc.
Tim
