Hi Marcus,
Does Red Bull has brake problems sometimes?
just being a smartarse - sorry
It would be/is, but if they use their trick engine map to reduce
the power output under this conditions significantly, you would only
have the loss in engine braking.
If the downforce advantage of the EBD is large enough, it is may worth it.
But in any case, you will need to brake more/harder, if you want the same entry speed.
Saying this, with more downforce from the EBD, you can maybe carry more speed into the corner, so the downside of the loss in engine braking is maybe not that big. - I don´t know, just some thoughts
Have a nice weekend
