Nose holes in the Ferrari style were certainly banned, but it looks like ones in the tip were still allowed:scarbs wrote:Timstr,
Great link, I'm struggling to see which chassis this is, it bears little resemblance to either the BGP001 or the RA108. How on earth did they get airflor to the front mounted cooler, Nose holes were banned under the 09 aero rules.
Also, from what i can see they would be right under the driver. So thats going to require something to get most of the heat away from the diver or they would be cooked by the end of the race.Tomba wrote: I'm still wondering about how they could position the batts in the nose (or under the tub). First of all, the height of the weight is a concern, no matter how low you try to put it into 'the keel' (especially interesting as F1 cars lack any kind of keel these days). You'd have your batteries almost certainly located above the wheel's centreline.
Honda in 2008 did test their KERS in a RA106, i belive the chassis was names the RA106-06K as the RA106 chassis only went up to RA106-05, and as Honda seemingly dodnt get to use 06 as Rubens was happy with 01 that year.scarbs wrote:Timstr,
Thats a good point, I looked up the pictures from that test. The few pictures of the Honda test car bore no resemblance to the car pictured, i.e. no undernose batteries or nose tip cooling inlet.ESPImperium wrote:Honda in 2008 did test their KERS in a RA106, i belive the chassis was names the RA106-06K as the RA106 chassis only went up to RA106-05, and as Honda seemingly dodnt get to use 06 as Rubens was happy with 01 that year.scarbs wrote:Timstr,
This is pretty consistant with what BMW Sauber did that year also, they built 9 F1.06s but F1.06-10 was named F1.06K-10 as it was the BMW KERS test bed. McLaren also had a Merceded KERS development car, but was never seen as it done all the work on a rolling road at Woking, and Ferarri tested a F2007 with KERS on it, but was only seen at Mugello and Marenello mainly in secret tests, and if Ferrari did do that it would be F2007K-265 that could have been used. As for Renault, im not so sure on that one, Toyota used a modified TF108 for their KERS and TF109-02K as well.
That would be a pretty plausable explination for such diagrams being used i think.
McLaren used batteries from A123Systems already back in 2009 and nothing significant have happend since then. Lithium iron phosphate can offer a high power density, but the energy density is quite poor compared to other chemistries. Of course, the latter is of little importance for F1.Raptor22 wrote:http://www.greencarcongress.com/2010/11 ... -7-kg.html
I wonder if part ofthsi technolkogy will find its way into the Mercedes W02 for 2011?
Brawn was assisting with the development of this unit.
Also, I think we will see significant weight reduction on the KERS next year with the use of A123 battery technology. These are the latest Lithium Iron nano PHosphate batteries
