have to hand it to Ferrari, that is some impressive packaging.
Sure makes the Mclaren (from the launch car) seem quite obscene
I know, I remember them bringing both specs for most races last year as after they added third flap.Diesel wrote:They'll bring both specs, it's standard practice, teams do it all the time. People just get too dramatic these days.mith wrote:I don't think that's the case. They've had enough time to manufacture spares. I think difference between both wings might be very slight and specific to circuit or driver linkings.
i agree that the ferrari exhaust gasses go over the top of the floor and not under it but i disagree about the diffuser. i think it doesnt go over the top off the diffuser, just around the sides. the reason i think that is look at the gurney flaps on the diffuser. there is quite a substantial flap on the top endge of the diffuser but none on the sides. makes me think they want to use the exhaust gasses and a virtual surface on both sides of the diffuser.Lindz wrote:Red Bull and Ferrari exhausts are both similar and very different.
Basically, they have the same position of the exhaust, but the Ferrari goes over the top of the floor and diffuser and the Red Bull goes under the floor to feed the diffuser.
You could well be right since the exhausts appear to point there, but I think it looks that way mostly from the camera angle. I don't see the point of blowing the exhausts over the floor (energizes and adds velocity to the ambient air) and then try and squeeze it between the diffuser and the inner rear wheels.Crabbia wrote:i agree that the ferrari exhaust gasses go over the top of the floor and not under it but i disagree about the diffuser. i think it doesnt go over the top off the diffuser, just around the sides. the reason i think that is look at the gurney flaps on the diffuser. there is quite a substantial flap on the top endge of the diffuser but none on the sides. makes me think they want to use the exhaust gasses and a virtual surface on both sides of the diffuser.Lindz wrote:Red Bull and Ferrari exhausts are both similar and very different.
I think that ferrari aim it is not to blow over the diffuser, nor exactly over the footplate, but instead to make the exhaust spill outside in the region betwen floor and rear wheels and warp around the footplate and increase energy in the side vortex inside the diffuser.Lindz wrote:You could well be right since the exhausts appear to point there, but I think it looks that way mostly from the camera angle. I don't see the point of blowing the exhausts over the floor (energizes and adds velocity to the ambient air) and then try and squeeze it between the diffuser and the inner rear wheels.Crabbia wrote:i agree that the ferrari exhaust gasses go over the top of the floor and not under it but i disagree about the diffuser. i think it doesnt go over the top off the diffuser, just around the sides. the reason i think that is look at the gurney flaps on the diffuser. there is quite a substantial flap on the top endge of the diffuser but none on the sides. makes me think they want to use the exhaust gasses and a virtual surface on both sides of the diffuser.Lindz wrote:Red Bull and Ferrari exhausts are both similar and very different.
The Gurney flap size is even more indication to me that they are blowing it over the top of the diffuser and under the beam wing. If there is more flow, more volume of air, the Gurney will need to be larger to have the same effect as less flow and smaller Gurney. Thus: a very large Gurney flap on top and almost none on the sides (almost no flow in proportion to that which is going over the top of the diffuser).
i think this image might confirm your theory shelly:shelly wrote: I think that ferrari aim it is not to blow over the diffuser, nor exactly over the footplate, but instead to make the exhaust spill outside in the region betwen floor and rear wheels and warp around the footplate and increase energy in the side vortex inside the diffuser.
I think gurneys are there to encourage and exploit this effect. Also remeber that gurney's back lower pressure is as important as gurney's front higher pressure: so also gurneys are there to help the diffuser not to separate.
Perhaps someone dropped it during assembly, or maybe it got damaged in transit?Robbobnob wrote:how can the body be broken? they haven't had FP1??
Exactly why does this make it clear? Because it's not on the car? Sorry sir, but rubbish.halllo_fireball wrote:[img]http://photos.gpupdate.net/large/171750.jpg[img]
I think this picture makes it quite clear, that the shape has not much to do with damage.
Have you ever seen a fractured cfrp laminate?! - This certainly is not.Hangaku wrote:Exactly why does this make it clear? Because it's not on the car? Sorry sir, but rubbish.halllo_fireball wrote:I think this picture makes it quite clear, that the shape has not much to do with damage.
More likely, they have had a production miscalculation, and have had to cut a small piece of bodywork away. That is not a smooth line, it almost looks like a tear.
Edit: If anything, this image above shows even more that it's not intentional - the reflection of the light is distinctly different around the area that is in question, perhaps indicating that the bodywork was pushed out from underneath.
