Hey folks.
I just am very curious as to what people think about Rob Wilson the driver coach. He's situated in Bruntingthorpe as I understand it. Why exactly did he never make the big time? Anyone know?
I watch Peter Windsor's weekly webcast, "The Flying Lap." I don't really pay much attention to Peter, but his guests are top-calibre.
Peter is good friends with Rob, and Rob has been on the show several times, either as pre-recorded, or live via Skype, or live in the studio.
I'm curious because some of the techniques he teaches seem (to me) somewhat unorthodox. Here's one of his better appearances:
[youtube]http://www.youtube.com/watch?v=Eyr2okX-kQw[/youtube]
Note that I say better because Rob here is talking the whole time, rather than just a half-hour Skype call or a 10 minute recorded conversation.
There are a few things that I'm confused about. One that is constantly of contention by myself is when he tells drivers to only diagonal the straight at the last possible comfortable moment, so that you don't kill some speed off at the start of the straight through tyre scrub. It's been debated hotly in another thread I created here: viewtopic.php?f=1&t=12636
Another thing I don't quite get is he tells drivers to, whenever possible, create what he calls a "flat spot." Basically this is saying to have a section of track, no matter how short, to have all four tyres pointing dead straight, as the car accelerates and brakes better in the absence of any lateral scrub from the tyres. He says Kimi is very good at this, and he says that Kimi, in the tiny straight between T1 and T2 at Bahrain, will have a moment where the car is just dead square.
Yet another is that he tells people to "shorten" the corner. I never really understood what he meant by shortening the corner at first, but then I looked at Pastor's Spanish GP Pole (yes, that leaves a bad taste in my mouth as he technically qualified P2 and was gifted pole, rather than qualifying a pole lap) lap and You could sort of see what is meant by "shortening" the corner and putting in a "flat spot." Shortening the corner is basically, the way I see it, shortening the distance traveled by decreasing the radius. ie pump in a lot of steering mid-corner.
Pastor pumps in a lot of steering at the apex of T1, and there is a moment - where for just 2 tenths or so where Pastor's wheel is straightened out, before he turns into 2. Here is said lap for reference:
[youtube]http://www.youtube.com/watch?v=aoMn51lt14g[/youtube]
The theory, as explained by Rob, is quite sound. Basically the car is slow anyways at the apex, and it can't do much in terms of braking and accelerating, so just do more rotation of the car at the apex, rather than having that angle hampering the car later on.
If you do such a technique - shortening said corner and straightening out when possible, yes, you do get a shorter time of rotation of the car, then better acceleration and braking as the car is just dealing with longitudinal loads and not lateral. But surely then you would have to sacrifice the apex speed in order to do this, and as such you carry less speed across. Does it have advantages? Yes - but I don't think it's a clear cut "better" technique.
He says that Jenson - who drives in his smooth, long arcs, is slower because of this - he spends too much time in the corner and "lengthens" the corner, and says that ultimately, getting the car turned more mid-corner is better. He was also praising Vettel's Monza pole lap last year (relative to Lewis' P2 lap) where in Parabolica, Vettel turns the car more at the apex and has a straighter exit, rather than Lewis, who uses the more conventional line through Parabolica of gradually drifting wide to the outside of the turn. ie "shortening" the car and creating a straighter exit line.
I'm not sure I entirely agree with this - I think it has to differ corner by corner. Or at least by categories of corners. I don't think tackling every corner on the circuit that way is the answer either.
Another issue I'm struggling to understand is that he seems to contradict himself. If you, as he calls it, "shorten" the corner, then surely that's a lot more lock mid corner, which would give you a slightly slower exit speed. But this would hurt the car just the same as turning the car early at the start of a diagonal line, would it not? His two lessons of only moving across a diagonal racing line near the braking zone seems to contradict his "shorten the corner" somewhat.
Thoughts, peeps?
I would like to kindly and respectfully ask that any and all driver examples and comparisons have their names substituted as "Driver A" and "Driver B" so as to keep this thread clean of the more comparisons more towards the technical aspects of the driving styles and lines rather than comparison of the drivers themselves
