Vodafone McLaren MP4-27 Mercedes
timbo
timbo
111
Re: Vodafone McLaren MP4-27 Mercedes
McMrocks wrote:
Dragonfly wrote:The lower ends of the pylons (attachment points?) look different between the two noses.
agree. Due to Fia tests?
I guess the upper one is just not fully assembled=)
kalinka
kalinka
According to an Autosport interview about Hamilton's bad setup in Japan : When quizzed on the exact nature of the problem, Hamilton added: "It's not a suspension failure, because I could still drive with it.
There was just a part that helps the balance and when you set it up it should react in one way but it didn't do that."
So what part could it be exactly, that helps the balance, and it's not a suspension failure?
furious_g
furious_g
kalinka wrote:According to an Autosport interview about Hamilton's bad setup in Japan : When quizzed on the exact nature of the problem, Hamilton added: "It's not a suspension failure, because I could still drive with it.
Well it can't be upright / wishbone / pushrod / spring / trackrod / rocker because a failure of any of these would most likely cause a DNF.
Which as far as i know narrows it down to damper / inerter / anti-roll bar. To my mind, his laguage suggests either inerter or anti-roll bar.
Hail22
144
Very interesting just saw on sky that a Mclaren mechanic/technician was working on the rear wing lower endplates/gills that would be awesome if they have an adjustment screw to tune/change the direction of the airflow coming from the exhaust/floor going to the beam wing/diffuser.
Gilles Villeneuve
That would be classified as a moveable part.
Meaning, rigid mechanical parts that enable at least one degree of freedom. Eg. pivots, belts, gears, sliders, cams, screws etc. Only sanctioned parts can be moveable.
WhiteBlue
92
The McLaren had a new engine sound in FP1 at half throttle. It sounds awful. I wonder if that was legal.
raymondu999
Nowadays I think they're still allowed to make map changes, but they have to provide a good reason, for example the change in air pressure that comes with the higher altitude of Interlagos. I'd think that's a potential loophole.
Having said that, with the Hockenheim hoo-hah over engine mapping I'd think the FIA has enough experience with the issue now. Do note though that the cars don't have to be in legal race spec, in FP
失败者找理由,成功者找方法
seinfeld
seinfeld
-7
WhiteBlue wrote:The McLaren had a new engine sound in FP1 at half throttle. It sounds awful. I wonder if that was legal.
I totally agree, it was at the low end of the rev range. sounded like traction control
aral
aral
26
Oh no! Here we go again! #-o #-o #-o
Please, no. :?
Nando
Nando
seinfeld wrote:I totally agree, it was at the low end of the rev range. sounded like traction control
It was the first thing that popped into my head when i heard it. Obviously it´s illegal but still an interesting sound.
Disclaimer: Nobody is saying they have it, just that it sounded like it.
Javert
23 4 Lewis Hamilton 14:34:19 308.4
24 3 Jenson Button 14:54:29 308.3
Both McLaren very bad on top speed
It's for the new engine map?
Arunas
Arunas
Javert wrote:23 4 Lewis Hamilton 14:34:19 308.4
May be not using DRS?
raymondu999
McLaren have fielded (to my reckoning) all 8 of their season engines. Perhaps they dialled the performance down to save engine life?
失败者找理由,成功者找方法
Kiril Varbanov
147
raymondu999 wrote:McLaren have fielded (to my reckoning) all 8 of their season engines. Perhaps they dialled the performance down to save engine life?
They have - in Japan, just as well as ROS, RAI and KOB.
