A one piece element, provided you can get it to work without stalling, would actually almost always produce less drag than a 2 element wing plane. The problem comes from trying to turn the airflow that much. To turn the airflow the less any part of either element that stalls the better and more effective the elements will be as a wing. They could not turn the airflow enough to go out of the slot in the end plate with one element without the wing stalling so therefore they used 2 elements.gandharva wrote:No, the text says one element has an offset of 45 degrees to the other. While the other one is parallel to the endplate. Both is wrong.turbof1 wrote:The drawing could have been more correct, but it has an angle of 45 degrees.
Both elements are more or less parallel to the outwards bend endpart of the endplate and imho are there to push more air away from the front tire. The elements imho are only separated to reduce the higher drag a one piece solution would provide.
*note* when I say wing I refer in this case to the vertically mounted 2 elements that make up the wing
