Manoah2u wrote:So seems like a unlucky gathering of unpleasent circumstances.
The tire mark isn't that weird either, it's not uncommon that just 1 wheel locks up under braking; it was an 'inside' wheel lockup, gravity affects F1 cars too thus turning to the right generates more load on the outer wheels compared to the inner wheels.
Yes but then the reverse argument is also true, that the other wheels should have had grip. With an inner wheel lockup only, you still have full directional control over the car as well as most of the braking ability avalable. Then the trajectory of the crash (curving inward) as well as the speed at impact are puzzling.
No matter which way you look at it is still a weird accident. And that is not because I don't believe that Alonso is some demigod who does not make mistakes. It is just that the location and the apparent trajectory of the crash are very unusual.
when you take the skidmark as reference you have to wonder i) how did he get there as it was far from the racing line, and ii) why did he continue like that. Logically one would expect him to either steer away from the wall or if the situation was irrecoverable to lock all brakes.
I'm sure that there is a logical explanation and I'm sure that it is not witheld purposely. And that does not include electrocution which in a carbon box seems next to impossible. But loss off spacial awareness, or accidentally hitting the throttle when slamming the brakes, could also be possible.
