You are correct to assume the engine cover is different. Compare it to Bahrain:Morteza wrote:I guess that would be correct, but where?turbof1 wrote:Is it correct to assume that a cooling inlet there will reduce an other somewhere else?
By the way here's the how it looks like from the side (is it the right word to use?). The engine cover looks different due to these new inlets or is it just the angle of this photo?
http://img3.auto-motor-und-sport.de/Nic ... 863304.jpg
Essentially they traded a bit of the flat shark fin for the ducting (and perhaps small radiators too) of the cooling inlets.
If I had to guess where they would reduce the cooling inlet somewhere else, it would be the sidepods. They could chip away at the radiators too with this, although not by much. I don't see any distinct difference on said sidepods, but this could simply be an intermediary test to have an idea how much they chip away with this.
It's a game of compromises. The new roll hoop inlets block a bit more airflow to the rear wing, while tighter sidepods would increase airflow over the diffuser.
