PlatinumZealot wrote:Brian Coat wrote:"Is there any evidence they are using an axial compressor ? Personally I doubt as I don't think you can generate the pressure ratio needed."
Should we entertain the possibility that it might be more radical than this?
You guys should visit the Honda PU thread. It was determined that within the realm of industry solutions the compressor is more like a "Mixed Flow" compressor. This looks similar to a regular centrifugal compressor on the outside but on the inside the geomoetry is slightly different, with an ejection angle oblique to the rotation axis instead of at 90 degrees. The advantage of this is increased flow per rotation which allows you to make the compressor smaller.
Whilst a mixed flow impeller is not out of the question, I'm not really convinced of the benefit even if it can provide more flow, the difference in diameter will be very small to a radial in the order of a few millimeters or the price will be paid in pressure ratio capability. Also by definition the compressor stage probably grows in length as the diffuser is now also angled.
Whilst other designs are possible a well designed radial compressor and well designed radial turbine are hard to beat for performance or compactness. It's not impossible in an f1 application that something else might be better its just I think you have a very hard time proving it.
In god we trust, everyone else brings evidence.
