SectorOne wrote:No that would be the slipstream. The number 1 cause for overtakes in lower formulas.
My point was more about the big picture. Spec-series cars don't have a locked-in performance advantage, which is untrue of cars in a developmental series. That means overtaking in a developmental series is always going to be more difficult, regardless of any and all elements that form the basis of performance differentiation, simply because advantages gained through technological development are vastly more consistent than even the very best drivers.
Combined with a qualifying format that arranges the structurally fast cars ahead of the structurally slow cars, you don't exactly have an ideal recipe for wheel-to-wheel racing, yanno?
The takeaway of that is this: unless the fundamental nature of F1 is altered, it will never consistently produce idyllic on-track battles. As such, I think it's best to manage expectations accordingly.
Andres125sx wrote:IMHO you look like obsessed trying to convice people that current cars use ground effects more than wings, like if wings are there only to aid GE.
Simply put, an inverted airfoil in ground effect creates downforce as a result of vortices that form along the end plates at the wing's point of peak suction. The low pressure literally sucks the wing to the ground.
On the other hand, an airfoil in freestream creates a pitching moment that rotates the wing, producing a downwash that causes lift.
To be continued...
