piast9 wrote:Boost wrote:GP2 cars don't use tyre blankets, so I'm not sure how Mitch can complain about a test that would have been performed at ambient on his car.
And that fact is the very important difference. If you have no warmers then you measure the pressure when tyres are cold with calibrated device and you have a realiable measurement. In F1 either you should measure the pressure before tyres go into the warmers or tyres that are in warmers at stable temperature.
Disqualifications based on the pressure measured when tyre is out of the blankets is crazy. That is not a realiable nor reproducable measurement! If there was a rain that cooled down the slicks then everyone would be dsq based on the pressures registered by the telemetry.
You can dsq because of the wrong dimensions, shapes, weight, etc, but n
ot a dynamically changing parameter such as the tyre pressure at unstable temperature.
Of course you can as long it breaks the rules - like in Raikkonen's case in Abu Dhabi '13. They failed floor deflection test after missing the part on the kerb (that's your dynamic part). Did it happen? Yes. Accident? Of course but it didn't matter. Stewards can accept or ignore any explanation and apply a penalty because measurement X is out of range. Do you think they measured gains or team's guilt? Look at this:
'"However, the stewards did not accept that the incident referred to constituted an accident, or excused failing the relevant test."
"AUTOSPORT understands that the stewards did not accept the explanation, unlike when there was a similar situation with Romain Grosjean in Hungary, because it did not feel that the incident at Turn 3 where Raikkonen ran off the track and broke the floor should be considered as accidental damage."
"The team respects the stewards' decision," team principal Eric Boullier said. "No advantage was sought or gained in the incident and the relevant part has been replaced.
"Did not feel" = interpretation. Yes, you run off track, break a floor and put the part back to cheat. It doesn't matter, hard measurement is a hard measurement.
Same here and A. difference in procedures does not work in Mercedes' favour (unknown area). B. It's safety and there's no compromises with safety, that didn't last long, did it?
Just like with racing under yellow flags at Silverstone '13 it was OK and then Bianchi's accident happens. Soft explanation is all it takes to get away with anything - this is the issue here, there are rules with data, documents and then people come and explain and it goes out of the window. In Lotus' '13 case there was a visual evidence with car going off track. Evans is right his tyres were outside the range (reference point for penalties) and so was Mercedes'. They chose to ignore it based on a team and politics as always.
