It's trough to the basement.ME4ME wrote:Your jaw must be on the floor
You've basically just ignored almost every race so far. Their chassis is widely lauded as the best. Even better than the Red Bulls this year. Their setup just isn't working well with the tyres at this track/surface/temps and they haven't been able to find out and solve it.Chene_Mostert wrote:Sort of disproves the common misconception that Mercedes AMG F1 has the "best" chassis, most "efficient" aero.
Their PU advantage has reduced over the past couple of months and this track exaggerates this. The Q3 gap at Monza was not Mercedes AMG F1 turning "down" their engines.
Their masked chassis shortcomings is properly the main deciding factor in not supplying RBR customer spec engines for 2016
condor wrote:It's to do with the tyre pressure limits. After Merc's problems in 2013 with overheating tyres, they've gone for a philosophy where the geometry doesn't work the tyres very hard. The problem though is that it requires lower tyre pressures. Lower tyre pressures cause the tyre carcass temp to heat up faster (less air, gets hotter) which matched to their suspension setup gets a perfect rise in pressure and temperature for both maximum contact area and getting the tyres into their thermal working range.
The FIA/Pirelli tyre pressure limits has hurt them because it is putting the tyres out of the working temp zone. It's interesting that the FIA and Pirelli are imposing these pressure limits on not just the high speed circuits but also the low speed ones now.
Nope, their PU is arguably the best.condor wrote:You've basically just ignored almost every race so far. Their chassis is widely lauded as the best. Even better than the Red Bulls this year. Their setup just isn't working well with the tyres at this track/surface/temps and they haven't been able to find out and solve it.Chene_Mostert wrote:Sort of disproves the common misconception that Mercedes AMG F1 has the "best" chassis, most "efficient" aero.
Rosberg also said the top 4 are out of reach.Sevach wrote:Hamilton doesn't think they'll finish on the podium.
"When I compare high-speed performance, if we had the [best] engine, I think we would be P2 [behind Mercedes]." -Verstappencondor wrote:You've basically just ignored almost every race so far. Their chassis is widely lauded as the best. Even better than the Red Bulls this year. Their setup just isn't working well with the tyres at this track/surface/temps and they haven't been able to find out and solve it.Chene_Mostert wrote:Sort of disproves the common misconception that Mercedes AMG F1 has the "best" chassis, most "efficient" aero.
Their PU *IS* the best, not even arguable. But that doesn't mean their chassis isn't also the best. Williams, Lotus, Force India also run this best PU but they're not even close to Mercedes AMG. The car simply isn't working well at Singapore. It worked very well at Monaco where Hamilton was dominating the race until the safety car error. That's also a low speed street circuit which requires excellent mechanical grip. Every track the Mercedes has been dominant. Except for Singapore where something clearly isn't right. If you think Singapore presents a uniquely true test of a chassis' mechanical grip and low/medium speed aero compared to Monaco, Hungary, Australia etc. then I suggest you please take the advice in your own signature.Chene_Mostert wrote:Nope, their PU is arguably the best.condor wrote:You've basically just ignored almost every race so far. Their chassis is widely lauded as the best. Even better than the Red Bulls this year. Their setup just isn't working well with the tyres at this track/surface/temps and they haven't been able to find out and solve it.Chene_Mostert wrote:Sort of disproves the common misconception that Mercedes AMG F1 has the "best" chassis, most "efficient" aero.
All season long we were told(and looked at numbers) how Mercedes made huge amounts of time on slow speed corners, which makes what happened today completely crazy.NoDivergence wrote:All season long they have dominated in every type of teach and were said by other teams to have highest corner speeds by GPS trace. Only thing that has changed this weekend is higher tire pressures.
