this recent information is not inconsistent with optimising combustion speed and consistency via a rather homogeneous leanish burn ?Frank_ wrote:aye spark onto the pilot injection, then progressively inject the rest of the fuel into that little fireball in the chamber ?ringo wrote:This sounds more like it to me. There is ignition in that little pocket initially.Frank_ wrote:chamber in the piston crown maybe ? akin to my diesel one
http://i65.tinypic.com/2ufrfvl.jpg
keeps the heat away from the cylinder walls (thermal efficiency)
a relatively inhomogeneous burn pattern ie 'keeping heat away from cylinder walls' must be extra hot somewhere or have extra air
neither is without costs ?
(as the rules prevent the compressor and turbine being over 80% efficient)
