TAG wrote:ChrisDanger wrote:TAG wrote:
I think when one starts to argue semantics, the point becomes secondary which is the only tactic to argue semantics. Let's let sleeping dogs lie since you're still unwilling to acknowledge that they're close only because of luck not despite it.
It's not semantics. He's clarifying what he meant by what he said, which you misinterpreted, yet you continue to stand by your misinterpretation. Like talking to a brick wall...
It's a body of work, and the clarifications still refuse to acknowledge the basic flaw in the assertion as other have chimed in, but it's okay you can't get too far on a dead end road.
The whole assertation points towards mechanical issues being a basic part of motorsport. You can like or you can not like it, but that is how it swings.
I acknowledged perfectly that is Rosberg is in front, because of the bad luck Hamilton had to endure. However, you yourself aren't exactly acknowledging that Rosberg did well enough of a job to capitalize on it. And, Hamilton is also in this position because he let himself down at a few critical moments. Especially in Japan, after the breakdown in Malaysia, where he needed to win (and the next races too) to stay master over his own faith. That bad start is equally haunting him now, as he clearly outshined Rosberg the last 3 races, but is unable to keep Rosberg from taking the title anyhow. That's due his car letting him down, but also because he let valuable points go to squander at a few moments, which now turn out to be critical.
Again, this is not withstanding Hamilton did better than Rosberg across the season. And he did have bad luck. But simply put the margins between him and his teammate were not big enough to avoid this situation. And Rosberg does deserve credit for maximizing every opportunity given to him, within his own capabilities.
That'll be the last I am going to say about this. The original point turned into too big of a discussion point on its own.
