williams copy others designs in the hope for improvements...but they seem to have a separate frontend designgroup of some sorts....as mentioned before I think one of the maindisadvantages of the tusks is the instability in terms of horizontal from side to side .This vibration is obvious in onboard shots where you can clearly see the wing assy moving /oscillating from side to side.wonder how that feels to the driver....I bet it is something like a starting rocket......JPM won´t bother,but the new nose will be soon anold story...as soon as the frontend design group gets their wakeupcall....
Interesting to spot the stiff setups they still run ,with porpoising and bouncing as bad as it could possibly get,no wonder the car is twitchy and unpredictable,but I fear it would be even worse if they let the car work a bit more thanks to a very pointy aero...ohoh...
marcush.
