Hi. I want to learn the material in this video which is shaped by CNC for producing redbull car's noose. At 50 sec they are sticking each other then machining for noose mould.
https://youtu.be/-t6cxIeCIjE
It's logical. I don't know how they're working . I am trying to do something with carbon fiber and mould making materials are more expensive than carbon fiber itself. If it's not serial production they can choose this way at least for trial designs.jjn9128 wrote: ↑08 Nov 2017, 12:42Why would they make a separate mould just for impact testing? If it's going to be produced for racing - there are at least 4 noses going to track, so at least 5 uses for the mould. I suppose to get the carbon right into the tip for something as sharp as that spec of nose cone would be tricky.
I thought the last team x-trac produced gearboxes for was manor?
That's a foam 'soft tool' used for rapid prototyping - the racing parts are made with proper graphite, ceramic or metal tools.jjn9128 wrote: ↑08 Nov 2017, 12:42Why would they make a separate mould just for impact testing? If it's going to be produced for racing - there are at least 4 noses going to track, so at least 5 uses for the mould. I suppose to get the carbon right into the tip for something as sharp as that spec of nose cone would be tricky.
I don't know which resin system you're using, probably rtc wet layup, if so, then your mould materials (especially if you're just experimenting) are basically anything, wood, plywood, mdf, foam board, etc, use automotive soft (polyester) bondo to do final shaping, spray some 2k primer on it, sand it and then spray 2 component automotive clear coat, wet sand, buff, wax and you're ready to make your moulds for parts, clear coat is necessary, because the vynil or polyester gelcoat that you'll be using, will dissolve and grab onto the bondo or the 2k primer used for the model, don't skip it
