So I changed the export settings from binary to ASCII and now the problem seems to be solved!LVDH wrote: ↑05 Dec 2017, 15:12Well after trying the first three stl files, I changed them all. If you want to check yourself, you will find a file called stl_db.mwf in the postProcessing folder. It does not get generated to the end. You can open it with a text editor and see where it gets stuck. That then indicates the problematic stl file.
Its great that it has been updated. Found there were a few issues with geometry, for example, I was messing with the front wing sliders and found the front wing geometry produced with certain settings would extend into the wheel arch and into the wheels. There was also an issue with the rear wing that when I dropped the wing height and changed the chord it made the wing support geometry go a bit mad.LVDH wrote: ↑04 Dec 2017, 10:48I just received a cool email: The CAESES app has been updated:
https://www.caeses.com/products/caeses/ ... pp/racecar
Oh! I think I missed this. Am I still in time? My birthday is in January, so it would make a hell of a birthday presentCAEdevice wrote: ↑08 Dec 2017, 13:01Hi everybdy, I received the requests for the book ("How to build a car" by Adrian Newey), by 8 guys (André, Evolve?, Jacopo, Lucasz, Adam, Richard B., Robert, Saad). Shipments will start from Monday, so it is possible that many of you will receive the book after Christmas (I apologize for the delay). The winner of the first prize will surely receive the book after Christmas (looking at the ranking it is certain that it will be JJR), because the dedication will take more time (I have to send a copy to RB and then to have it back).
I did, I posted about it just above your post.
