But it does mean my theory can be correct. As we saw in the vestappen video, he got a light on his dash before the green light went out. He got a slight jump on it because there's no way he'd reach the marshalling post before the VSC period endednevill3 wrote: ↑15 May 2018, 22:46Here is the relevant section from the sporting regs...So the time delta is set by the FIA and sent to the drivers dash, each marshalling sector is between the flashing panels. I do not see how driving "shorter distances" would help.40.5 All competing cars must reduce speed and stay above the minimum time set by the FIA ECU at
least once in each marshalling sector (a marshalling sector is defined as the section of track
between each of the FIA light panels). In addition, any driver entering the pit lane whilst the VSC
procedure is in use must be above the minimum time set by the FIA ECU at the first safety car line
as he enters the pit lane.
All cars must also be above this minimum time when the FIA light panels change to green (see
40.7 below).
When initiated during a race, the stewards may impose either of the penalties under Article
38.3a), b), c) or d) on any driver who fails to stay above the minimum time as required by the
above.
40.6 With the exception of the cases listed under a) to d) below, no driver may overtake
another car on the track whilst the VSC procedure is in use.
The exceptions are :
a) When entering the pits a driver may pass another car remaining on the track after he has
reached the first safety car line.
b) When leaving the pits a driver may overtake, or be overtaken by, another car on the track
before he reaches the second safety car line.
c) Whilst in the pit entry, pit lane or pit exit a driver may overtake another car which is
also in one of these three areas.
d) If any car slows with an obvious problem.
Her's a diagram of what I mean. This is with VSC about to end.
Marshall post
Car A - - - - - - - |- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - > |
Car B - - - - - - - |- ->
There's a half second to go on the VSC. Car A is about to reach a timing post, so has to keep going at the same 60% speed otherwise he'll be done for speeding when he breaks the timing beam
However, Car B can now start to accelerate, so long as he doesn't reach Marshall post 2 before the end of the VSC he can go as fast as he likes. So when the VSC actually ends the cars are more like this.
Marshall post
Car A - - - - - - - |- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -|->
Car B - - - - - - - |- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - ->
Car B has been foot to the floor for half a second longer so is able to make up significant ground and have better momentum.
That's why I believe that Verstappen got that flash on his dash before the marshall flag went green. He had an opportunity to make up ground wihtout breaking the VSC rules. It wouldn't take much for the teams to create VSC programme that used the GPS of the cars to know exactly when the driver could start to accelerate and that split second advantage could have a significant impact in giving a chance to overtake.
If teams aren't doing this, then they should probably start!
