roon wrote: ↑27 Jun 2018, 08:46
rscsr wrote: ↑27 Jun 2018, 08:34
roon wrote: ↑27 Jun 2018, 08:20
Rough start for Ocon. Bumped by Grosjean, taken out by Gasly. Either a big lack of situational awareness, or just malice, on Grosjean's part. Odd.
the Gasly crash was certainly Ocon's fault.
As in, he shouldn't have cut over as much as he did? Looked like Ocon was following a good line, which doesn't always work in traffic. I guess Gasly lost the back end trying to avoid him.
Its' the start of a race, there are people alongside going into the first few corners if the track isn't the type to be single file into the very first corner and here with contacts and collisions everyone was even more bunched up.
You can't just be on the very outside and cut over to the apex. I've been incredibly critical of Massa for doing this throughout his career. He flipped his own car over in Germany by deciding that despite being on the outside line screw everyone he wanted the apex, cut across found a car there and caused a collision. As always with Massa he blamed the other driver. What's great from that video for that particular crash is after Massa/Magnussen hit about 4 other pairs of drivers go through that corner side by side, not one other driver cut from the outside line to the apex because not one other driver was stupid enough to do so.
He was on the outside line, way way outside as it goes, he had cars very close on the inside, most other drivers actually stuck roughly to their lines in that corner because they are aware that switching lines in such situations usually lead to contacts.
Ocon tried to blame Grosjean for the car damage when talking about the Gasly crash. To me it suggests Ocon saw it, knew it was entirely his fault but tried to pass it off as car damage caused him to pull to the right.
Grosjean is a complete idiot and hit Ocon for no reason at all, Ocon was a complete idiot in changing lines like that. Later in the race when you know who is around you and if a car is close do what you want, first lap with cars going through alongside each other (and the cars directly ahead did so also so it's clear this is possible), hell no. Vettel, honestly, complete idiot. He messed up the first corner but with a damaged car and far less control than usual he went back onto the track and caused a second collision with Grosjean. It should be plainly clear to him that he had a decent amount of damage and would have front wing damage and not the best ability to turn into a corner so he should have been slow and in all honest using the run off to stay out of the way.
So much stupidity in the first lap.
