Other than aesthetics, is there a particular modelling problem with the step?What do you think about this fix to the "rear step" rule?
I only ask because in-season rule changes probably mess people up a bit...?
Sorry, I was talking about the new rulebook (near wheels volume: most car did not even consider the change... not sure they are fully legal...)
I'm not against it, but I never liked that part on real LMP and I wouldn't like to see it on our cars. Also, it might mess up some airflows... the diffuser is a delicate area.CAEdevice wrote: ↑22 Aug 2018, 18:32Hi, we talked about it here in the forum, but it was too late to introduce any change before the first race.
http://www.caedevice.net/SERVER/MVRC/20 ... r_LMP1.jpg
Are you sure you need it to be so low? My gearbox cover is all above the "cut"
Your diffuser is quite high at the centre... It also doesn't have a pronounced double inflection, which helps by that point of view.
Ok, but why does your gearbox cover is so low? It is inside the diffuser? Wouldn't be better to have it above the diffuser if the diffuser is so low?
Thank you very much! I definetly like the idea to show to rulecheck!LVDH wrote: ↑23 Aug 2018, 18:12Hi guys,
so Richard and I have completed the compliance checks. Please keep in mind that this is the first time we both did it. There is obviously a chance that we overlooked some violations. So for the next race you should all check your cars against the rules. Just because something passed this time does not make it legal. There was a lot of back and forth about the CAEdevice rear wing. Figuring out if it violated the rules or not was pretty hard. It seems though that the only issue were the end plates which are a bit too sculpted and received a warning. The full results can be found here:
https://mantiumchallenge.com/scrutineer ... mans-2018/
You can click through the slide show. Three teams have received penalties. This is a bit much but two of the teams were newcomers and getting everything right the first time is pretty difficult.
