Lewis Pole vs Vettel Q3 2nd lap onboard (tks to Juzh's clips).
https://streamable.com/1s552
Vettel was a couple of km/h lower through almost all corners but Ferrari had better acceleration and higher top speed, so Vettel was pretty much neck and neck with Lewis, until turn 13 where he had a huge lockup. And then turn 14 he had a poor corner exit. These two mistakes caused huge lap time. Lewis was a little bit conservative throught the last two corners tho.
BTW, Lewis made a brilliant choice through turn 16 (01:19 part). Vettel ran over the kerbs, which I assume is "supposed" to be the usual line for a better turn 17 entry, but it gave the car a little lift, unselling the car a little bit. Lewis avoided the kerbs, which not only gave him faster cornering speed, but also allowed him an earlier corner exit accelaration. And that didn't compromise his turn 17 at all as he still had a higher turn 17 apex speed than Vettel. This is beautiful. This reminds me of the 2017 Suzuka quali. Everyone else ran over the kerbs of turn1 of the last chicane, but Lewis chosed to avoid that, which gave him an advantage. You can find his own comment on his Suzuka pole in this vid.
https://www.youtube.com/watch?v=ONIieL9GTSw
