I agree that a longer stable rule period helps to, at least at the front, bring the cars closer. I also think they made the mistake of making the cars wider. All data and experiences in the past pointed towards less "racy" cars and with the increased downforce making it harder to overtake or even be following close. They try to fix that now.Big Tea wrote: ↑19 Sep 2018, 11:24I think this, and the rules for construction being so restrictive is the main cause. Id there were different ways to build the car, the cars would have better performance in different areas. The best example is at the start of the previous turbo era. Option one, nimble car, advantage around corners and twisty bits. Option 2. brute force, fly by on the straight.WaikeCU wrote: ↑19 Sep 2018, 10:26Maybe the constant change in technical regulations is the problem? I remember whenever the technical regulations are somewhat set for a few seasons, the gaps between cars starts to decrease. It's radical technical regulation changes that lead to bigger gaps, because that's just like a reset button.
I believe we have seen three big technical regulation changes in the last 4 seasons:
- Hybrid era V6
- Wider cars, lower rear wings, bigger tires
- Halo
To me that's massive, whereas if you compare this to late 90's and early 2000, I believe we didn't had that massive changes from 1999 to 2005? Is it?
With all cars the same weight engine type and basic design where one is good/not-so-good they all wil be.
But they will spend the same amount in F1, if its all on one concept or spread over several. Either the concept has to be simple enough for new builders to get up and running in a couple of years or there needs to be a 'back door' such as Haas have used. For instance, and this is just off the top of my head, so do not get into the nitty- gritty, if an alternative car option of say 500kg 1ltr 4 cyl but limit to 1000cc. I know the problems now are going to be the weight of the safety 'cell' but just an example. Also, it took the gumption of Renault to make the dive to turbo to make it happen. There is not similar opportunity today. You fit this engine full stop.Jolle wrote: ↑19 Sep 2018, 11:46Big Tea wrote: ↑19 Sep 2018, 11:24I think this, and the rules for construction being so restrictive is the main cause. Id there were different ways to build the car, the cars would have better performance in different areas. The best example is at the start of the previous turbo era. Option one, nimble car, advantage around corners and twisty bits. Option 2. brute force, fly by on the straight.WaikeCU wrote: ↑19 Sep 2018, 10:26Maybe the constant change in technical regulations is the problem? I remember whenever the technical regulations are somewhat set for a few seasons, the gaps between cars starts to decrease. It's radical technical regulation changes that lead to bigger gaps, because that's just like a reset button.
- Hybrid era V6
- Halo
With more open rules, or different formula's, you get lots of different concepts the first year and the winning one will be copied the year after, with all the teams that choose wrong on the back foot and with massive budget spendings. Next to that, if you have two choices, lets say, a v4 or v6, a team like mercedes will develop both to choose which one delivers best, while with a mandated v6, they only need the budget to develop one. etc etc
I have a brilliant idea. Maybe F1 should race on air strips that are 100m wide so that overtaking will not be a problem. If that's too silly for you, how about an oval?Andres125sx wrote: ↑18 Sep 2018, 20:07IMHO when the leader can go several seconds slower than posible and still the second car can´t even consider an overtake, something is wrong with that formula.
It's a contradiction really. The thing about cost saving is true with limited amount of crucial parts such as PU's and gearboxes, heck even tires (life), but then you introduce radical technical changes, which requires a large investment by the teams, so you can't hardly call it cost saving anymore... I think F1 needs to really look at themselves and check the financial health of teams before introducing any technical changes for the future.Big Tea wrote: ↑19 Sep 2018, 12:04But they will spend the same amount in F1, if its all on one concept or spread over several. Either the concept has to be simple enough for new builders to get up and running in a couple of years or there needs to be a 'back door' such as Haas have used. For instance, and this is just off the top of my head, so do not get into the nitty- gritty, if an alternative car option of say 500kg 1ltr 4 cyl but limit to 1000cc. I know the problems now are going to be the weight of the safety 'cell' but just an example. Also, it took the gumption of Renault to make the dive to turbo to make it happen. There is not similar opportunity today. You fit this engine full stop.Jolle wrote: ↑19 Sep 2018, 11:46Big Tea wrote: ↑19 Sep 2018, 11:24
Although Formula one costs a lot, there really isn't a financial problem. The big four have no problem with spending so much money, even the only works team really without a big sponsor said last week "money is no problem" (Renault). Even when a team gets into financial trouble, there are more then one willing to invest (as we saw with Force India and now with the financial injection of Latifi at McLaren). Formula one also never has been this close, a while back they introduced the 107% rule to get rid of some opportunists, there hasn't been a team even close, apart from Manor maybe when they ran a year old car. In "the good old days" where many here are referring to, it was quite normal for one team to lap the entire field.WaikeCU wrote: ↑19 Sep 2018, 13:14It's a contradiction really. The thing about cost saving is true with limited amount of crucial parts such as PU's and gearboxes, heck even tires (life), but then you introduce radical technical changes, which requires a large investment by the teams, so you can't hardly call it cost saving anymore... I think F1 needs to really look at themselves and check the financial health of teams before introducing any technical changes for the future.Big Tea wrote: ↑19 Sep 2018, 12:04But they will spend the same amount in F1, if its all on one concept or spread over several. Either the concept has to be simple enough for new builders to get up and running in a couple of years or there needs to be a 'back door' such as Haas have used. For instance, and this is just off the top of my head, so do not get into the nitty- gritty, if an alternative car option of say 500kg 1ltr 4 cyl but limit to 1000cc. I know the problems now are going to be the weight of the safety 'cell' but just an example. Also, it took the gumption of Renault to make the dive to turbo to make it happen. There is not similar opportunity today. You fit this engine full stop.Jolle wrote: ↑19 Sep 2018, 11:46
Id say pretty much every top formula of motorsport is the same.
If points were awarded for fastest lap, the Red Bulls would win it every race, being 5th and 6th mostly, they could pit for a new set of tyres, then come out still in 5th and 6th as there is a HUGE gap to 7th 8th ect. It wouldnt change anything other than a few more points for Max and DannyJust_a_fan wrote: ↑19 Sep 2018, 14:43F1 is a season-long chess game. It is not 90 minutes long. The aim is to get through the season with the most points, not the most number of overtakes or fastest laps.
Of course, one could give points for fastest lap - it might encourage the midfield, but the front teams would rather be super reliable and win points from being on the podium.
Phil wrote: ↑19 Sep 2018, 12:11I have a brilliant idea. Maybe F1 should race on air strips that are 100m wide so that overtaking will not be a problem. If that's too silly for you, how about an oval?Andres125sx wrote: ↑18 Sep 2018, 20:07IMHO when the leader can go several seconds slower than posible and still the second car can´t even consider an overtake, something is wrong with that formula.
Corners exists in F1 since day 1 in 1950. Do you think overtaking is as easy/difficult as always? Obviously not, so let me dare to say there are other factors affecting overtaking difficulty, like aerodynamics
Or we can just accept that right now, F1 has 21 different tracks with a lot of diversity. We have tracks where passing is relatively easy, we have tracks that are highspeed, we have low downforce circuits, we have high downforce circuits, we have street circuits where any mistake is likely a DNF and, we have... yes, we also have some circuits where overtaking is close to impossible, that *shock* allow drivers to dictate the pace of those behind for strategic reasons.
We should appreciate the fact that each of these tracks pose different challenges to overcome and to succeed on. Both Monaco and Singapore have a legitimate values: They may not offer the most spectacular racing, but they place the importance on qualifying and emphasis on strategy during the race. I'll take that diversity over 21 Silverstones where Hamilton came from dead last back to 2nd any day of the week.
And I really get annoyed with people like you obsessed with posting on threads he don´t like.... posting on threads you don´t like to provoke people participating in that thread can be seen as trolling Phil
Are you serious??NathanOlder wrote: ↑19 Sep 2018, 16:22Id say pretty much every top formula of motorsport is the same.
Example Moto GP Brno GP.
If with 5 laps to go Pol Espargaro on the KTM came in for a new set of tyres, he was capable of lapping a 1.56.3 as he did that time on the saturday,
Now the fastest lap of the race was set by Lorenzo which was a 1.56.6. Pol qualified 20th I think, which is last on an F1 grid, how is that any different ?
So people are only allowed to post on this thread if they agree with you?Andres125sx wrote: ↑19 Sep 2018, 17:34
If you disagree it´s fine. But it´s also fine if I think something need to be changed and start a thread to share my point of view. If you don´t like it, do not click, it is this easy
