Why would it be pointless? If you had it run too much hotter it'd be useless because nobody would set their cars up to generate the heat required, and being lower grip it gets harder to generate the required energy as you get harder and harder compounds anyway.
A wide heat range relatively close together with enough variation to cope with different track temperatures is
good thing, not a bad one.
