2019 Aston Martin Red Bull Racing - Honda F1 Team
Re: 2019 Aston Martin Red Bull Racing - Honda F1 Team
FPV GTHO wrote:
11 Feb 2019, 02:14
godlameroso wrote:
10 Feb 2019, 21:43
By the second week of testing we'll know if whether Red Bull has a fighting chance in hell or not. If they're within .3 or even .5 on the long runs, they'll be in reasonable shape to catch up. If it's more than that, they'll have their work cut out for them.
Last year they were within .5 on the long runs and won races, I expect similar performance with a similar gap.
I don't think it's long run pace holding them back. They need qualifying pace with the higher powered engine modes.
I do, in fact that has up to now, been Honda's greatest weakness as a power unit. Well it was weak everywhere until the last quarter of last year. They seem to have unlocked some one lap pace, however I still think they'll need some more to get the long run pace of the others. The bottlenecks are a mixture of reliability and efficiency that will come from exploiting the ERS with the extra power. Improving the combustion process yields not just improvements in power and efficiency, but also allows more ERS recovery and deployment as well.
However since the regulations force you to transfer that energy via indirect means, they by extension require unconventional thinking.
Let me put it this way, suppose the engine naked by itself with the fuel restrictions could produce maximum around 700hp (+-40hp by building an engineering masterpiece or mediocre dud) where does the other 300hp come from? Answer, the ERS. 160hp comes from the MGU-K, we all know that. However that leaves the math short, MGU-K + ICE = 860hp only. Where's the other give or take 100hp? The MGU-H of course(however the MGU-H is only good for about 80hp or so), but you say, the MGU-H doesn't propel the car that's ludicrous. I say it does, just not directly, remember the engine is being robbed of power to produce boost pressure from the turbo. If the MGU-H takes up the power needed to drive the turbo, that power is freed from having to spin the turbo and can instead spin the crankshaft. (the turbo is in essence driving the pistons by controlling the airflow being combusted, and thus has a fluid coupling with the drivetrain)
If Honda could develop their extra harvest(due to better efficiency from the ICE) they could maximize this extra power for longer periods, right now they can only do it for a qualifying lap because there is no restriction on fuel level, or requirement to have the battery last for multiple laps.
Honda's aim for the season is to develop the power unit so that fuel efficiency and reliablity improve so they can run the max power mode for longer, while getting closer to that max theoretical 740hp from the ICE. With improved ICE efficiency they can afford to burn more fuel to get more harvesting from the MGU-H. This opens the doors to new strategies with how to harvest with the MGU-H, how long wastegates can be opened, or how much in order to harvest enough energy for continuous running.
GPR-A
37
ME4ME wrote:
10 Feb 2019, 20:11
Regardless, you handily swirl around the point I was making that Red Bull-Renaults issues started well in advance of Renault getting their own team. Can you admit and agree to that?
You cherry picked one part of my original post, which was a reply to @caris2k and now you are surprised if I did the same? :)
I actually agree with your point about RB Renault issues. In fact, I am sure there are a lot more reasons than what I or you think are primary reasons for the sourness of their relationship, which we may or may not have paid attention to OR which might not even be available in public domain.
jagunx51
185
probably "more" white on the car?
Squid
Squid
jagunx51 wrote:
12 Feb 2019, 01:10
https://www.instagram.com/p/BtwBZ47HzgU ... _copy_link
Don't hold your breath for it. The RB14's logo also had a thick white border.
etusch
131
Squid wrote:
12 Feb 2019, 06:14
jagunx51 wrote:
12 Feb 2019, 01:10
This time they use white a bit more. Arter seeing helmet designs and then this it is expectable.
dxpetrov
dxpetrov
-7
Blue hue seems different as well.
HPD
198
Just_a_fan wrote:
10 Feb 2019, 21:56
I can see teams being cagey in testing. Simulators let them know their performance so they don't need to be entirely representative at the test days. Australia will let us know...
Look at the tests of 2018. Almost every day we had Ferrari, Mercedes and Red Bull in the first places.
It will give us an idea of ​​the hierarchical order.
HiddenIncome_
(deleted)
RedBull decided to crash Mercedes' launch / shake down with their own. Should be using opposite ends of the circuit though I don't which is using which end.
etusch
131
After seeing second car with no big changes, I am expecting to see more (almost) same looking cars. It looks like every car will have same sidepod inlets. I wonder if there a different design and still I wonder Redbull car.
gandharva
252
Do we know when they are going to unveil their new car?
TNTHead
the rumour is at 14.00 gmt
Sieper
73
15:00 CET I heared
GhostF1
GhostF1
110
