I don't see why asphalt runoffs are a matter of opinion. They are necessary.
The fact is that leca (gravel) traps are dangerous.
"Gravel traps on road racing courses should be paved over so drivers can steer, brake and recover" -- John Fitch --
Now, if you know a little about barriers, you know who Mr. Fitch is and then you agree with him. If you don't know who he is, perhaps you can find very quickly.
Jhon Fitch in the 60's before receiving the Kenneth Stonex Award from the Transportation Research Board, National Academy of Sciences, for his lifelong contributions in the field of roadside safety
Now, from a really old TRB magazine, I find this (which I've already posted three years ago, pardon me for being so insistent):
The entire series of tests on gravel traps indicate a deceleration of only 0.5 G, or the rate of moderate braking for a passenger car.
The full scale study determined that even this modest rate does not begin until the car has slowed to 50 mph. This compares to a 3 to 4 G braking capability for Formula One cars on a paved surface. Then there are the lesser problems of cars being eliminated from races due to damage caused by the gravel, or by simply getting stuck."
Transportation Research Record 1233, 1989, Design and Testing of Roadside Safety Devices
1989. It's not exactly yesterday's news.
Why would you need road barriers to slow down drivers? Perhaps if they were blind you'll need them, so they can hear the sound of the crash. For most of us, a line is enough.
On the other hand, if the drivers are deaf (like in the case of Hamilton), foam barriers are useless because they will not hear the sound of the crash.
Finally, if you wish to decelerate mildly (and wildly) a car, as WB proposes, use a gravel trap. That, or invent a new barrier by yourself, it's probably
easy to do, why should we waste time with expensive tests and fancy university professors?
