The key here is about finding the right balance between a safe solution and a fair one. Honestly I think that's where the Valencia street circuit really hit the nail on the head.
The small rumble strip chicanes on the inside run offs were perfect. They weren't like barriers so relatively safe but they were just tall enough to give a single seater a nasty bump and almost certainly some damage. Although they didn't get much action in the F1 race I did see some GP2 cars cutting the corners, having enough asphalt to slow down but then having to weave around this low speed chicane. That would have definitely sorted things out at Spa although in my mind there was nothing to sort out.
Another instance of asphalt run offs being used was Hockenheim. People said that Hamilton pushed Massa and Piquet off the track. In fact what he did was a regular block pass which would have made the others back off should there have been grass. Because of the asphalt it actually gave Massa in particular more of an advantage, in that he could maintain momentum and gain traction off the track and not fall behind as much. He was accelerating out on a part of the track that allowed him to stay with Hamilton and he chose to use that run off, he wasn't forced onto it.
rjsa wrote:EDIT: Just watched the spagate again. Had the barriers started some 20m earlier on the inside kerb LH would have braked propperly and taken the chicane.
It's not just the spelling here that makes my skin itch. To imply that outbraking someone in order to make a passing manoeuvre is not 'proper' isn't something I expect to hear from a motor racing fan. Perhaps F1 should be full of limp-dicks who are too afraid to even try and overtake in case of hurting someone's feelings. Would that be more proper? I might be picking on the wording a little but I think it's mentality like that which is killing racing today.
The road to success is 20,832 meters long...
