djones wrote: ↑08 Jan 2020, 14:29
Are the Ferrari style side pods meant to give less drag or something?
If they have less drag, what is the downside to them?
The high-top sidepods allow for a greater undercut. Air approaching this sidepod design is diverted downward around the sidepod and creates higher pressure over the floor at the rear of the car.
Essentially, the airflow is fed into the diffuser area, boosting the diffuser's performance. This is beneficial because the diffuser is a source for tremendous downforce and aerodynamic efficiency. In sum, adopting the high-top sidepods is a great way to generate some more downforce (via the floor and diffuser) without incurring a subsequent drag penalty.
Consequently, the rear wing AoA can be alleviated, creating even less drag (and facilitating greater top speed performance).
Scarbs has a great diagram illustrating the difference in undercut size:
While the visual change will be fairly dramatic, it's more about marginal gains (better efficiency, less drag). The areas that are still most ripe for development after the recent regulation changes are the front wing and bargeboard sections.
