saviour stivala wrote: ↑18 Feb 2020, 17:38
The present forced induction ICE is fuel restricted to a maximum power speed of
somewhere between 10500rpm
and 15,000rpm,
which is 4500rpm below its permitted maximum RPM of 15000.
Correction in red.
“None of this applies to the current F1 (power unit)”. On the contrary, all of it applies to the current F1 (power unit). We are still talking about an ICE that burns fuel to make power. The differences, while the NA ICE was always air restricted by design/optimised/tuned to achieve maximum power speed at a point 500rpm bellow the maximum RPM it could safely withstand for at least a race distance, and or whatever maximum RPM that was imposed.
The current engines are designed to operate with significant amounts of excess air throughout the normal operating region. This means that small changes (say +or-10%) in airflow at a particular speed (say 11,000 rpm) have very little effect on the power output. On the other hand, a similar change in fuel flow will produce approximately +or- 10% change in power.
Furthermore, if we ignore changes in BTE, the airflow required to produce the same AFR and power all the way from 10,500 to 15,000 is constant. With increasing revs and constant airflow, the air mass inducted per cycle will reduce (as noted by TC on many occasions). As a result, boost pressure needs to reduce to maintain constant airflow as revs increase above 10,500. This is even more true since the introduction of variable intake runners allowing correct wave tuning at all rpm.
The consequence of the above is that breathing ability plays almost no part in the designer's choice of operating rpm. The two main criteria in making this choice are:
1. Widest possible power band to reduce gearshifts. The ideal would be peak power near 12,750 rpm and near-constant power from 10,500 to 15,000.
2. Reducing mechanical (and possibly thermodynamic) efficiency as rpm increase. Because of this the designer will choose a lower peak-power-speed, slightly above 10,500 and an operating range from just below 10,500 to somewhere above the peak-power-speed.
So I agree with TC - none of that airflow-limited power curve stuff applies to current F1.
