But if you remember correctly FIA was very late with that info. Binotto told that this was strange, because it was only on one car and only on this race, and they were monitored at least 10 times before. And because of a late call they didn't have time to recheck. FIA was under big pressure from Mercedes and RB (Honda) because Ferrari became too strong (power wise). Who knows what is behind curtains.Sieper wrote: ↑02 Mar 2020, 23:23And then overfuel by 4.4kg effectively putting the nail in the coffin. That makes no sense.zokipirlo wrote: ↑02 Mar 2020, 21:50Season was lost already. Second or third place doesn't matter. Maybe they just detune engine a little so other teams will shut up. Who knows.Jip wrote: ↑02 Mar 2020, 17:12
Do you have an explanation then why Ferrari suddenly had a big pace deficit as soon as a TD was issued, and before that really had one of the best cars on the grid? And why would there be a settlement, if there was nothing wrong with the engine. If that was the case, the FIA wouldn't have settled anything and as you say, we wouldn't hear anything of it. So I really don't understand that people say Ferrari did nothing wrong, we still don't know what they exactly did wrong, but that's for the FIA to say.
I want to use this message to highlight why this doesn't belong here: This is not a thread about morals or if a punishment is fitting. This is simply a topic about hardware and in such the whole scope of illegality here, is limited to determining if the hardware does not comply to to regulatory framework.
Any fuel that passes through the FFS have to end-up burned in combustion chamber and the maximum flow permitted is 100kg/h @ 10500rpm.One and Only wrote: ↑02 Mar 2020, 19:01I don't think there was ever more than 100kg of fuel in LeClerc's car. Aa far as I can remember discrepancy was from 90 to 95 or something like that. Someone correct me if I'm wrong, but I think you can have more fuel in the car. You just can't burn more than 100kg/hr.supermarine wrote: ↑02 Mar 2020, 17:13The annoying thing about the way this has been handled is that the really interesting technical details will never be known. I would love to know how Ferrari were doing what they were doing and how much extra fuel they were able to get into the engine than was legal as a result.
Does the 4.88kg anomaly in LeClerc's fuel load at Abu Dhabi tell us anything about the latter? Being really simplistic about it, if we assume they should have had about 100kg of fuel in the car does that mean Ferrari were using around 5% extra than they were admitting to? If so, was the performance advantage of the Ferrari PU we were seeing consistent with fuel flow rate of around 105kg/hr? Anyone have any thoughts?
Questions for tech savvy people who know the rules: Is it legal/possible to get fuel mixture (very poor with fuel) into the combustion chamber, but not burn it during off throttle, then store it somewhere else and return to engine via turbo during throttle phase (early throttle phase)? It is not stored anywhere before injectors. What are the rules for fuel after it passes trough injectors? I have really basic knowledge of ICE and turbo so don't be harsh with replies
Let assume that Ferrari made this deal...LM10 wrote: ↑03 Mar 2020, 00:43But the thing is that the FIA doesn't need to figure out what was going on when it's Ferrari telling them.subcritical71 wrote: ↑03 Mar 2020, 00:29I think it would be to avoid 'prosecution' in case the FIA eventually figure out what was going on. It was a safety net for Ferrari and a reasonable one at that.LM10 wrote: ↑03 Mar 2020, 00:20
Let's consider this is the case. Why would it be of importance for other teams not to find out what Ferrari has been up to, once the loophole is closed by the FIA? The way I understand it is that Ferrari needed to tell the FIA their secrets because they still couldn't monitor what was going on - this way they will be able to close the loophole. But once this happened, how do Ferrari take advantage of it by keeping their secret to themselves and the FIA?
Thanks for clarification. Do rules define when it has to end-up burned in combustion chamber? In both cases it will end-up there.saviour stivala wrote: ↑03 Mar 2020, 10:58Any fuel that passes through the FFS have to end-up burned in combustion chamber and the maximum flow permitted is 100kg/h @ 10500rpm.One and Only wrote: ↑02 Mar 2020, 19:01I don't think there was ever more than 100kg of fuel in LeClerc's car. Aa far as I can remember discrepancy was from 90 to 95 or something like that. Someone correct me if I'm wrong, but I think you can have more fuel in the car. You just can't burn more than 100kg/hr.supermarine wrote: ↑02 Mar 2020, 17:13The annoying thing about the way this has been handled is that the really interesting technical details will never be known. I would love to know how Ferrari were doing what they were doing and how much extra fuel they were able to get into the engine than was legal as a result.
As far as I'm aware, the rules only forbid storing fuel past the fuel flow sensor.One and Only wrote: ↑03 Mar 2020, 14:29Thanks for clarification. Do rules define when it has to end-up burned in combustion chamber? In both cases it will end-up there.saviour stivala wrote: ↑03 Mar 2020, 10:58Any fuel that passes through the FFS have to end-up burned in combustion chamber and the maximum flow permitted is 100kg/h @ 10500rpm.One and Only wrote: ↑02 Mar 2020, 19:01
The rules don't state that fuel must be burned in the combustion chamber, only that all metered fuel must pass through the combustion chamber.scarnegie96 wrote: ↑03 Mar 2020, 14:40...One and Only wrote: ↑03 Mar 2020, 14:29Thanks for clarification. Do rules define when it has to end-up burned in combustion chamber? In both cases it will end-up there.saviour stivala wrote: ↑03 Mar 2020, 10:58Any fuel that passes through the FFS have to end-up burned in combustion chamber and the maximum flow permitted is 100kg/h @ 10500rpm.
If the rules stated that fuel can only be burned within the combustion chamber then Honda's solution would be illegal surely.
I really prefer your understanding of the FIA press release. According to me, there is big political fight between the 3 top teams and the FIA.Mr.G wrote: ↑03 Mar 2020, 13:00Let assume that Ferrari made this deal...LM10 wrote: ↑03 Mar 2020, 00:43But the thing is that the FIA doesn't need to figure out what was going on when it's Ferrari telling them.subcritical71 wrote: ↑03 Mar 2020, 00:29
"We will tell you what are we doing (because it's loop hole and you will never find it without help). As it is loop hole we will use it during 2020. Because we are telling you, you will restrict it for 2021 but not sooner than end of the year (to avoid other to copy mid season)..."
3jawchuck wrote: ↑03 Mar 2020, 15:15The rules don't state that fuel must be burned in the combustion chamber, only that all metered fuel must pass through the combustion chamber.scarnegie96 wrote: ↑03 Mar 2020, 14:40...One and Only wrote: ↑03 Mar 2020, 14:29
You have not given a reason why the FIA are under this seemingly great motivation to get to the bottom of what Ferrari are doing. If they determine the Ferrari PU is legal then it’s legal and all discussions end. The FIA announce it, the championship commences - none of this is what happened.Mr.G wrote: ↑03 Mar 2020, 13:00Let assume that Ferrari made this deal...LM10 wrote: ↑03 Mar 2020, 00:43But the thing is that the FIA doesn't need to figure out what was going on when it's Ferrari telling them.subcritical71 wrote: ↑03 Mar 2020, 00:29
I just said what many apparently are thinking. Ok I got it.turbof1 wrote: ↑03 Mar 2020, 10:46I want to use this message to highlight why this doesn't belong here: This is not a thread about morals or if a punishment is fitting. This is simply a topic about hardware and in such the whole scope of illegality here, is limited to determining if the hardware does not comply to to regulatory framework.
So please, let us do that. I admittingly agree that what the FIA did, is shady. But it will not get us more insights lamenting it.
At first it's not a fine (not proven)...214270 wrote: ↑03 Mar 2020, 16:35You have not given a reason why the FIA are under this seemingly great motivation to get to the bottom of what Ferrari are doing. If they determine the Ferrari PU is legal then it’s legal and all discussions end. The FIA announce it, the championship commences - none of this is what happened.Mr.G wrote: ↑03 Mar 2020, 13:00Let assume that Ferrari made this deal...
Moreover it doesn’t explain the ‘fine’ that was handed out to Ferrari either.
