Guess I missed a few posts
You mentioned previously that an electric motor has a more suitable torque curve, which is of course a fact. But you miss 6 gears so a lot of torque. A Tesla motor maybe does 12000rpm at top speed? The first 1000rpm aren't great efficiency wise. Having to tow in that region, and than going to maximum motor torque has impact on the thermal stability.Andres125sx wrote: ↑27 Apr 2020, 11:01I don't. What's the reason it should be different to ICEs? I've read nothing which explains the difference, if it really exist
In the UK, anyone who attained their licence after 1 Jan 1997 already has limits on what they can tow without taking a special test:J.A.W. wrote: ↑27 Apr 2020, 10:08How many passenger cars do you see towing anything these days?Ferry wrote: ↑26 Apr 2020, 12:23Audi e-tron, Jaguar i-Pace, Mercedes-Benz EQC, Nissan e-NV200, Tesla Mod. 3.Just_a_fan wrote: ↑24 Apr 2020, 10:28I'm not sure any EV is rated to tow, other than the Tesla Model X,
Soon to come: Audi e-tron Sportback, Audi Q4 e-tron, Ford Mustang Mach-E, Polestar 2, Volvo XC40 Recharge, Skoda Vision iV, VW ID.4
I'd expect that'd be next on the 'banned list' due to 'safety reg's' &/or subject to extra licensing...
How much fuel does engine braking use over normal idle? Why should the engine be using fuel when not being asked to provide power? In my vehicle, when one comes off the throttle, the instantaneous mpg display goes through the roof, and engine braking occurs.Andres125sx wrote: ↑27 Apr 2020, 11:29But modern ICEV have almost zero engine braking for better fuel efficiency, some even less than what regen providehenry wrote: ↑27 Apr 2020, 11:18Andres125sx wrote: ↑27 Apr 2020, 11:01
ICEs can always use engine braking, BEVs can’t guarantee that regen, which is the equivalent, is available at all times. So BEVs need bigger brakes for prolonged braking.
This happens in F1. At many circuits the deployment strategy has to make sure there is available regen capacity for the big stops towards the end of the lap because the rear physical brakes aren’t sized to do that repeatedly.
Mine doesn't. The only battery in it is the big 100Ah 12V starting battery in the engine bay.
CORRECTION - the Tesla 3 has SWITCHED RELUCTANCE machine(s) making it go and regenerate-slowTommy Cookers wrote: ↑24 Apr 2020, 12:09... the Tesla 3 iirc having induction machines (making it go and regenerate-slow) it is spectacularly unsuited to towing
with an open loop system the 'controller' only works as certified if the EV characteristic matches that programmed
A whole lot! I guess that is very different in different markets. Tow hitch on small cars like VW Golf or similar is very common here. Not many pick-up trucks though. One of the big selling points for Tesla 3 here is the possibility to tow. And EVs have more than 50% market share here now. https://cleantechnica.com/2020/02/05/no ... r-on-year/
I´m not familiar with modern cars either, but the bmw of my father has so little engine braking it did surprise me first time I drove ithenry wrote: ↑27 Apr 2020, 11:59I’m not familiar with that, not much experience with modern cars. My last 2 cars, both autos, have downshifted on downhill, zero throttle, and provided engine braking. How does not doing this help fuel efficiency?Andres125sx wrote: ↑27 Apr 2020, 11:29But modern ICEV have almost zero engine braking for better fuel efficiency, some even less than what regen providehenry wrote: ↑27 Apr 2020, 11:18
If the battery is full regen will be zero.
As I´ve just explained, it´s not the fuel it takes when one comes off the throttle, but the time you need to keep your foot on the throttle, much longer with engine braking than withoutJust_a_fan wrote: ↑27 Apr 2020, 15:43How much fuel does engine braking use over normal idle? Why should the engine be using fuel when not being asked to provide power? In my vehicle, when one comes off the throttle, the instantaneous mpg display goes through the roof, and engine braking occurs.Andres125sx wrote: ↑27 Apr 2020, 11:29But modern ICEV have almost zero engine braking for better fuel efficiency, some even less than what regen providehenry wrote: ↑27 Apr 2020, 11:18
Reading your two posts, I think you're confusing engine braking with drag. Modern cars are slippery so when you come off the throttle they don't slow down very quickly. Of course, a man on a bike is not slippery, he's quite a drag load so will help to slow the bike. The car has much more inertia, being much more massive, but also being more aerodynamic has similar drag. Hence the car tends to feel less effect off throttle than the bike. CdA comparison by looking at these two random google-found sources (if better sources can be pointed to, that would be great) :
This chart shows otherwise, efficiency at very low speed is quite goodBrake Horse Power wrote: ↑27 Apr 2020, 14:02You mentioned previously that an electric motor has a more suitable torque curve, which is of course a fact. But you miss 6 gears so a lot of torque. A Tesla motor maybe does 12000rpm at top speed? The first 1000rpm aren't great efficiency wise. Having to tow in that region, and than going to maximum motor torque has impact on the thermal stability.Andres125sx wrote: ↑27 Apr 2020, 11:01I don't. What's the reason it should be different to ICEs? I've read nothing which explains the difference, if it really exist
Than you have the question, is this governing for the motorsizing (or cooling system) or other parts like gears etc. If so the next question is, as raised here, how many people actually need to tow a lot? And do you want to adjust design accordingly making it more expensive for the masses to please a few.
I'm aware about drag, but drag difference is not that high between modern and old cars and engine braking difference is very noticeable even at 50kmh when drag is negligibleJust_a_fan wrote: ↑28 Apr 2020, 09:51Reading your two posts, I think you're confusing engine braking with drag. Modern cars are slippery so when you come off the throttle they don't slow down very quickly. Of course, a man on a bike is not slippery, he's quite a drag load so will help to slow the bike. The car has much more inertia, being much more massive, but also being more aerodynamic has similar drag. Hence the car tends to feel less effect off throttle than the bike. CdA comparison by looking at these two random google-found sources (if better sources can be pointed to, that would be great) :
http://elmoto.net/showthread.php?t=3400
https://en.wikipedia.org/wiki/Automobil ... oefficient
Obviously the rider's position makes a big difference e.g. crouched behind a fairing vs sat more upright in the breeze.
For engine braking when towing, I'm talking about using lower gears to help with speed control, not just coming off the throttle.
With EVs, one needs to stay on the "throttle" longer because as soon as you come off it, you start to get regen braking although I think you can often adjust this feature to give more/less braking when off throttle. Some EVs can be driven as a single pedal system other than for the last bit of stopping - much like your bike example, in effect. How good that is at holding back an additional load e.g. a big trailer, I don't know. Maybe it's now been worked out and that's why towing capability is being seen in the latest models.
Modern cars will have only 60% of the drag of old cars. That's a big difference.Andres125sx wrote: ↑28 Apr 2020, 11:38
