sandeep, what type of CFD analysis you hoping to do, external aerodynamics, internal fluid flow, chemical reactions, super sonic flow???
Russell Harrison
Forced Convection Design Engineer, Comair Rotron Europe Ltd
CFD is based around assumptions; the accuracy of the solution depends not only on the knowledge of the mathematics behind the software but the assumptions the user makes!!!
and of how accurate an analysis you hoping for. For instance, say modeling a front wing, would you be happy with 100,000 mesh elements, 700,000, or would you want 1.5 million mesh elements??
Russell Harrison
