Holm86
247
Re: 2022 Aero Thread
tangodjango wrote:
30 Sep 2020, 13:17
Blackout wrote:
28 Sep 2020, 21:50
That 2022 model with 2020ish sidepods:
https://i.imgur.com/MayOFoG.jpg
Will they really be that much shorter???
2022 regulations says a maximum wheelbase of 3600mm, which is about the same as the W11 is now, which is stupidly long. And I think 2022 cars will be at that maximum, so I don't expect them to be shorter ...
jjn9128
778
tangodjango wrote:
30 Sep 2020, 13:17
Blackout wrote:
28 Sep 2020, 21:50
Not at all. The wheelbase will come down from ~3750mm for the Merc to 3600mm as a maximum. But the front overhang is longer by ~125mm so the overall length pretty much evens out.
#aerogandalf
tangodjango
tangodjango
Holm86 wrote:
30 Sep 2020, 14:02
tangodjango wrote:
30 Sep 2020, 13:17
Blackout wrote:
28 Sep 2020, 21:50
What a pity.
“Hamilton’s talent is perhaps even more than that of Ayrton or Schumacher or Fernando." - Rubens Barrichello
jjn9128
778
The wheelbase could easily have been limited to 3200-3400mm. We've all seen the gearbox case is ~1m long these days. Could even have been shorter as they run a narrower/longer fuel cell to shrink the sidepod width.
#aerogandalf
Xwang
Xwang
29
jjn9128 wrote:
30 Sep 2020, 15:37
I agree and I would have not increased the front overhang. Moreover the front wing keeps too much wide (as it is in today cars). I would have reduced it to the width of the body (140 or 160 cm).
OO7
OO7
171
Another 3D design of the 2022 cars: https://www.turbosquid.com/3d-models/fo ... el-1489859
I'm beginning to think that the 2022 rules will get scraped if we have a good 2021 season. The 2022 spec cars(which let's face it, are now essentially spec cars), is going to turn F1 into Euro Indy car. With spec cars and nearly spec engines, with the same politics that determine who wins in American Indy Car.
JordanMugen
85
Xwang wrote:
30 Sep 2020, 15:51
But that is necessary to reduce front tyre wake (and hence allow close following), by deflecting air away from the front tyres?
godlameroso wrote:
05 Oct 2020, 17:10
Agreed. It all feels like a move to a Euro Indy. Future plan - worldwide Indy?
jjn9128 wrote:
30 Sep 2020, 15:37
Teams complained and the FIA foolishly gave in.
jjn9128
778
Sevach wrote:
06 Oct 2020, 05:26
The lunatics are running the asylum.
#aerogandalf
JordanMugen
85
Just_a_fan wrote:
05 Oct 2020, 20:30
Indycar power unit & running costs are far more reasonable, so that would not be such a bad idea! :)
Indycars have a far more reasonable level of build quality, compared to overly elaborate Grand Prix cars. The fit & finish is more like a Grand Prix car from 35 years ago -- sensible, affordable and economically prudent! :)
2018 Dallara - Honda
1988 McLaren - Honda
2015 McLaren - Honda
Not an ounce of free space! Just an absurd level of oversophistication due to being able to throw unlimited amounts of money at the problem... don't you think? #-o
subcritical71
90
JordanMugen wrote:
06 Oct 2020, 20:40
Just_a_fan wrote:
05 Oct 2020, 20:30
https://www.autoracing1.com/wp-content/ ... ngine2.jpg
https://external-preview.redd.it/tVlZia ... 3f237e753b
https://cdn-1.motorsport.com/static/img ... 398511.jpg
I think this has more to do with the aero rules. If Indy didn’t have fixed bodywork they would most likely go down the same rabbit hole as F1.
jjn9128
778
subcritical71 wrote:
06 Oct 2020, 23:43
That's also the original DW12 which was delta shaped, i.e. bodywork was wide at the rear tyres like a Le Mans car (you can tell because the air intake is above the driver). The IR18 Indycar body and manufacturer bodykits before were a little tighter in the packaging.
#aerogandalf
FW17
169
A reminder;
Indycar does not have an intercooler system, so the works inside the sidepod is going to look a lot cleaner.
