Yeah, snowflake. I am not the one calling for penalties for swearing FFS. LOLHoffman900 wrote: ↑08 May 2021, 15:41Mr tough guy throwing around the “snowflake” term while simultaneously being triggered by people complaining about Yuki’s outbursts...
I think people handle it just fine, it’s just annoying.
I’m fine with swearing per se and do it a lot, but just think it sets a really bad example to any young people watching and shows a lack of self control. These guys are meant to be role models. Like I said in the heat of the moment with a crash or an impact then fine, but not a string of expletives for no good reason.mistrx wrote: ↑08 May 2021, 15:40Why penalties? Can't you handle it? Aren't you a grown person? If he swears too much the only problem it creates is for him as his team won't be impressed (unless he overperforms consistently) and might get rid of him.El Scorchio wrote: ↑08 May 2021, 15:36I was thinking the same thing actually. Was quite excited about him in Bahrain, but not since.NathanOlder wrote: ↑08 May 2021, 15:34Tsunoda already flopping, not even able to replicate Gasly or Albon's first few races. Plus he has a bad attitude and is constantly swearing on the radio. Not impressed since his first go out in Bahrain.
Personally I think they should start handing out fines or penalties to drivers for excessive swearing over the radio. Heat of the moment is fine but not just a string of expletives after the horse has bolted.
Are people such a snowflakes (and I might add hypocrites) these days?
Either the Mercs are sandbagging or the Red Bull really is still the class of the field. I guess we'll find out soon enough.
Very much doubt the mediums will get you to Q3. Field is too tight. This is flipping awesome.NathanOlder wrote: ↑08 May 2021, 15:43Merc leaving room for improvement ? Now switch to the mediums. Where as Max probably gone flat out so cant use mediums now ?
Edit - nope.
Man, I was off. Q3 cutoff was a 1:18.1godlameroso wrote: ↑04 May 2021, 19:19Bahrain showed us Mercedes lost 2 seconds, and RBR 1.3. If we compare 2020 qualifying and add those numbers we get 17.5 pole. Just interesting to see. I have a feeling Verstappen will knock this one out of the park though.
Then again the new turn 10 has minimum apex speed of ~83km/h in a very fast road car, so in an F1 car that number may be 130km/h, which will likely shave some time off the lap. Roughly .3 perhaps? So pole perhaps will be low 17's, with a mid 18's cut off for Q3. The new turn 10 is somewhere in between an average of turn 5 and turn 12 corner speed.
Well they had 8 tenths margin, the delta between the soft and medium can't be more than that.Herr_Koos wrote: ↑08 May 2021, 15:48Very much doubt the mediums will get you to Q3. Field is too tight. This is flipping awesome.NathanOlder wrote: ↑08 May 2021, 15:43Merc leaving room for improvement ? Now switch to the mediums. Where as Max probably gone flat out so cant use mediums now ?
Edit - nope.
I guess they were just used for an installation lap in another session ?
He did do an outlap in q1 on softs, maybe those are the ones he used.NathanOlder wrote: ↑08 May 2021, 15:55I guess they were just used for an installation lap in another session ?
As Jenson just said, teams don't like it, and drivers shouldn't do it.mistrx wrote: ↑08 May 2021, 15:40Why penalties? Can't you handle it? Aren't you a grown person? If he swears too much the only problem it creates is for him as his team won't be impressed (unless he overperforms consistently) and might get rid of him.El Scorchio wrote: ↑08 May 2021, 15:36I was thinking the same thing actually. Was quite excited about him in Bahrain, but not since.NathanOlder wrote: ↑08 May 2021, 15:34Tsunoda already flopping, not even able to replicate Gasly or Albon's first few races. Plus he has a bad attitude and is constantly swearing on the radio. Not impressed since his first go out in Bahrain.
