Correction, I was looking at this map that doesn't actually consider turn 2 and 4 turns anymore.
Ah alright, makes more sense, thanks.Juzh wrote: ↑26 Jun 2021, 13:27Hamilton was on a push lap and verstappen let him trough the lap before, but then hamilton just after being let trough in S3 decided to stomp on brakes and basically decided to hinder verstappen's lap. He didn't complete a flying lap and then went into pits the lap after, but not before holding up verstappen in T6-T7.
You nailed it.RZS10 wrote: ↑26 Jun 2021, 13:42Ah alright, makes more sense, thanks.Juzh wrote: ↑26 Jun 2021, 13:27Hamilton was on a push lap and verstappen let him trough the lap before, but then hamilton just after being let trough in S3 decided to stomp on brakes and basically decided to hinder verstappen's lap. He didn't complete a flying lap and then went into pits the lap after, but not before holding up verstappen in T6-T7.
So Max let Lewis through, who on the following lap did not go for it but ended up being on the outside in that corner, where Max felt it cost him some time, before going into the pits - is that the order of events or were there two similar instances? It's not quite clear from your post.
I think it was about the Hamilton moment too. They didn’t have any such moments this weekend but it happened twice before this year.RZS10 wrote: ↑26 Jun 2021, 13:18Didn't he get purple in that sector?
Edit: it was about Hamilton but it's a bit weird, isn't it ... did they already have any coming together on track this weekend?
And with traffic it's really hard to tell ... 2tenths can be lost quite easily because of a car in the wrong place at the wrong time.
Ok, so 5 place drop for Lewis?Juzh wrote: ↑26 Jun 2021, 13:44You nailed it.RZS10 wrote: ↑26 Jun 2021, 13:42Ah alright, makes more sense, thanks.Juzh wrote: ↑26 Jun 2021, 13:27Hamilton was on a push lap and verstappen let him trough the lap before, but then hamilton just after being let trough in S3 decided to stomp on brakes and basically decided to hinder verstappen's lap. He didn't complete a flying lap and then went into pits the lap after, but not before holding up verstappen in T6-T7.
It happens a lot, the posts are just getting removed by the moderation staff! I report my fair share of them every race weekend.
Ok, as they should. I could still find the quotes I made back though. Please, just don’t do it. It only angers people. Just come back on the topic, like f.e. RZS10 above. That way we can learn what happened and share our view (and alter our viewpoints) much better. Otherwise heels just get dug deeper in the mud.
It feels like Max is feeling the heat of the championship... to get worked up like that for a an incident were Lewis was on the outside of turn 7, which practically didn't impede him at all, just Max getting spooked by a car being there.. like Ant Davidson said Lewis can't disappear of the track to the nearest air filed when Max comes214270 wrote: ↑26 Jun 2021, 13:39Seems like VER doing a Michael Jordan “I took it personally”. He needs to motivate himself and is using any such incident even the non-existent/minor ones to basically anger himself and channel that into performance.dans79 wrote: ↑26 Jun 2021, 13:33I just went back and watched Max's onboard (f1tv has the replay up), and he wasn't hindered by either Latifi or Lewis.
He passed Latifi on the strait (and might have even gotten a little help).
Lewis was well in front through turn 4, and in front and well off the racing line entering turn 5.
Ant Davidson was saying Merc usually don't do any quly race with full engine at 9 and do a quly sim.... so according to Ant maybe they r changing their approach to give them more confidence and car improvement during thr actual event
No, but he can make sure he isn’t there. Like Max did for him the lap before. It was max his one real hot lap on fresh reds with low fuel. In any case, just FP so we will see later who takes pole.siskue2005 wrote: ↑26 Jun 2021, 13:57It feels like Max is feeling the heat of the championship... to get worked up like that for a an incident were Lewis was on the outside of turn 7, which practically didn't impede him at all, just Max getting spooked by a car being there.. like Ant Davidson said Lewis can't disappear of the track to the nearest air filed when Max comes214270 wrote: ↑26 Jun 2021, 13:39Seems like VER doing a Michael Jordan “I took it personally”. He needs to motivate himself and is using any such incident even the non-existent/minor ones to basically anger himself and channel that into performance.dans79 wrote: ↑26 Jun 2021, 13:33I just went back and watched Max's onboard (f1tv has the replay up), and he wasn't hindered by either Latifi or Lewis.
Lewis has to do his own things with his car... he can't just roll over like a puppy for Max... when Max comes within his range the team will inform him to move over on this corner, that's exactly what Lewis did within the rules set by FIA. The world doesn't spin around Max you knowSieper wrote: ↑26 Jun 2021, 14:05No, but he can make sure he isn’t there. Like Max did for him the lap before. It was max his one real hot lap on fresh reds with low fuel. In any case, just FP so we will see later who takes pole.siskue2005 wrote: ↑26 Jun 2021, 13:57It feels like Max is feeling the heat of the championship... to get worked up like that for a an incident were Lewis was on the outside of turn 7, which practically didn't impede him at all, just Max getting spooked by a car being there.. like Ant Davidson said Lewis can't disappear of the track to the nearest air filed when Max comes
No one's stopping him though.siskue2005 wrote: ↑26 Jun 2021, 14:07Lewis has to do his own things with his car... he can't just roll over like a puppy for Max... when Max comes within his range the team will inform him to move over on this corner, that's exactly what Lewis did within the rules set by FIA. The world doesn't spin around Max you knowSieper wrote: ↑26 Jun 2021, 14:05No, but he can make sure he isn’t there. Like Max did for him the lap before. It was max his one real hot lap on fresh reds with low fuel. In any case, just FP so we will see later who takes pole.siskue2005 wrote: ↑26 Jun 2021, 13:57
You say repeatedly that Mercedes is the fastest on a regular basis but I think you're a RedBull guy at heart.Sieper wrote: ↑26 Jun 2021, 13:25Purple in sector 3 only. Did he get hindered by Latifi earlier in the lap? Was not televised and I don’t have f1 tv streams to follow the driver. Let’s hope (from my point of view) he ca still fight for pole. From where I am standing Merc is again 2 of the 3 fastest cars and Hamilton on pole.
He's just being a dick. Max lets him trough on good faith, then brakes and blocks him. No other way to spin it. Waiting for another plausible explanation.siskue2005 wrote: ↑26 Jun 2021, 14:07Lewis has to do his own things with his car... he can't just roll over like a puppy for Max... when Max comes within his range the team will inform him to move over on this corner, that's exactly what Lewis did within the rules set by FIA. The world doesn't spin around Max you knowSieper wrote: ↑26 Jun 2021, 14:05No, but he can make sure he isn’t there. Like Max did for him the lap before. It was max his one real hot lap on fresh reds with low fuel. In any case, just FP so we will see later who takes pole.siskue2005 wrote: ↑26 Jun 2021, 13:57
